Author Topic: Isuzu I-Mark diesel  (Read 110335 times)
Reply #60November 22, 2010, 08:32:31 pm
truckinwagen
  • 1895
Re: Isuzu I-Mark diesel
« Reply #60 on: November 22, 2010, 08:32:31 pm »
yeah, diesel and isuzu are almost synonymous.
as for starting, isuzu likes to only start the glowplugs when cranking starts.
on cold days most of the time I have to put it in gear(so the NSS keeps it from cranking) and turn the key to START for a few seconds to force the glow plugs to fire before I put it back in park and start it for real.
-Owen
83 Opel Kadett Diesel
Reply #61November 23, 2010, 10:10:06 am
truckinwagen
  • 1895
« Reply #61 on: November 23, 2010, 10:10:06 am »
ok, what do you guys think about these wheels?
they are from a toyota MR2 and are a staggered set with 15" up front and 16" in the back.
its a killer deal, and I have been looking for a set of summer wheels and tires so I can stop paying to have tires swapped.
I think they will fit nicely, and look good once I get a chance to drop the front of the car a little bit.
-Owen
Reply #62November 23, 2010, 10:35:18 am
« Reply #62 on: November 23, 2010, 10:35:18 am »
should look REAL good..
alot better than the butt rockin 80's steelies on it now.
Reply #63November 23, 2010, 10:42:16 am
truckinwagen
  • 1895
« Reply #63 on: November 23, 2010, 10:42:16 am »
I'll have you know that the wheels on it now are 80's alloy "sport" wheels.
but yeah, I think the new set will suit it nicely, and should handle much better(not so much sidewall flex)
-Owen
Reply #64November 23, 2010, 02:52:14 pm
maxfax
  • 2126
« Reply #64 on: November 23, 2010, 02:52:14 pm »
The tractor has manual gp's..  On a 90 degree day it requires being gp'ed to heck.. And usually afterglow till it picks up and runs..  It has the 4BA1 engine..  A few years newer they changed something on the head that made them start easier..  Not sure if it changed compression or what..  ???
Thumbs up on the wheels though!
Reply #65November 24, 2010, 12:21:49 pm
« Reply #65 on: November 24, 2010, 12:21:49 pm »
-Owen
oh yea! thats right, your car has those super pimpin 80's mags on it!
Reply #66November 24, 2010, 07:21:49 pm
truckinwagen
  • 1895
« Reply #66 on: November 24, 2010, 07:21:49 pm »
yeah, I actually quite like the mags on it now, but I need a second set for summers, and loosing some sidewall will help handling substantially.
also today my alternator finally went, it started charging at 18 volts, so I pulled the brushes and one of them has been eating into the commutator, so the alt is junk(not rebuildable in the least)
so I disconnected the alternator and ran off my battery for the rest of the day, and put it on the charger when I got home.
ordered a new alternator from rockauto(along with a new e-brake cable) so until the parts come in I will be either charging at nights or driving my uncles truck, which I hate...
I think I will go ahead and do my manual brake swap while I am at it.
-Owen
Reply #67November 25, 2010, 02:20:12 am
maxfax
  • 2126
« Reply #67 on: November 25, 2010, 02:20:12 am »
Good you caught it before things started going poof..  I'd imagine things such as a dash cluster are not real nice to find..
Reply #68November 25, 2010, 09:39:47 am
truckinwagen
  • 1895
« Reply #68 on: November 25, 2010, 09:39:47 am »
yeah, I was actually kinda surprised things didnt go poof, I had to drive for longer than I would have liked with it charging at 18+(anchorage traffic wouldn't let me get off the road as fast as I would have liked)
it seems that everything survived, the dash cluster is still good, and the glow plug controller is still good too.
-Owen
Reply #69November 25, 2010, 11:08:38 am
truckinwagen
  • 1895
« Reply #69 on: November 25, 2010, 11:08:38 am »
well, I picked up the wheels!
rear fits perfectly, but the front will need a small spacer(1/2" or so) to both clear the shock and deal with the fact that the centerbore in the new wheels is slightly too small.
but don't they look good?
Reply #70November 25, 2010, 11:19:22 am
« Reply #70 on: November 25, 2010, 11:19:22 am »
looks good!
Reply #71November 25, 2010, 04:15:45 pm
maxfax
  • 2126
« Reply #71 on: November 25, 2010, 04:15:45 pm »
They'd look better with smoke rolling from them..   ;D
« Last Edit: November 25, 2010, 07:45:43 pm by maxfax »
Reply #72November 25, 2010, 07:37:39 pm
truckinwagen
  • 1895
« Reply #72 on: November 25, 2010, 07:37:39 pm »
yeah, I am currently working on my supercharger brackets to help with the tire smoke issue...
I am modeling a manifold in CAD to mount the charger to the intake.
unfortunately I may have to clearance the hood some to clear it(by either by cutting it some, or making brackets to hold the back of the hood up)
-Owen
Reply #73November 25, 2010, 07:48:10 pm
maxfax
  • 2126
« Reply #73 on: November 25, 2010, 07:48:10 pm »
A ram air hood would look pretty sweet on that!  8)   Guess there aren't too many aftermarket hoods for an I-mark..
Reply #74November 25, 2010, 07:52:32 pm
truckinwagen
  • 1895
« Reply #74 on: November 25, 2010, 07:52:32 pm »
nope, and all the prefabbed scoops/cowls are wayyyy to expensive for the little bit of fiberglass that they are.
I think that modifying the hinges to make the rear of the hood sit 2-3 inches higher would do the trick, which would double as a way to keep underhood temps down.
