Author Topic: 1984 Rabbit IDI Swap  (Read 2924 times)
August 05, 2010, 12:57:09 pm
jaysen71581
  • 211
    Hagerstown, MD
« on: August 05, 2010, 12:57:09 pm »
Hey guys, ive been reading quite a few posts today and had a few questions, i have an '84 Rabbit that had a gas motor in it, well i took all the gas harness out and have a full diesel harness out of an '84 donor diesel rabbit, instead of putting in the 1.6 na diesel motor i have a 1.6 turbo diesel motor, other than getting rid of the gas fuel pumps, since i have an complete uncut harness am i going to have to do anything special or should this just be plug and play?
Reply #1August 05, 2010, 03:06:28 pm
arsenicpants
Re: 1984 Rabbit IDI Swap
« Reply #1 on: August 05, 2010, 03:06:28 pm »
your fuel filler neck will be different
the diesel filler is a slightly larger diameter
there may be other things, but i don't think so
i've never done a gas to diesel swap
Reply #2August 05, 2010, 03:46:43 pm
BAM
« Reply #2 on: August 05, 2010, 03:46:43 pm »
You will have to swap your relays or the whole fuse box what ever is easiest.  so glow plugs work.  Remove "gas only" tag at filler neck you can change the filler or gut it.  The fuel tanks are different but a pain to change, I would take the high pressure pump out of the system and leave the in tank pump to feed the IP.  When I think of more i'll post.  Getting to do a MK3 swap in the next couple days.
Reply #3August 06, 2010, 02:48:08 pm
« Reply #3 on: August 06, 2010, 02:48:08 pm »
pretty sure rabbits only have 1 fuel pump?
Reply #4August 06, 2010, 02:55:11 pm
« Reply #4 on: August 06, 2010, 02:55:11 pm »
The 83 CIS GTI I have has 2, maybe certain models???
Reply #5August 06, 2010, 08:23:06 pm
clarkrep
  • 117
« Reply #5 on: August 06, 2010, 08:23:06 pm »
My '83 GTI had a single pump before the td swap. As far as I know they only had one pump on mk1s factory anyway.
Btw if you decide not to use the cis pump I would like to have another as long as it works.
Aaron
'79 Rabbit Diesel L 1.5
'83 Rabbit GTI 1.6TD
Reply #6August 06, 2010, 09:33:49 pm
NintendoKD
  • 931
    dnahtasinoivilboeraweb
    • myspace page
« Reply #6 on: August 06, 2010, 09:33:49 pm »
oh.......... OH! Joygasm :o  I just love the 84 prolly the best mk1 year EVER!
Reply #7August 07, 2010, 02:11:37 pm
« Reply #7 on: August 07, 2010, 02:11:37 pm »
i like anything but 84s. they are like a mk1.5 some mk1 traits, lots of mk2 traits.. my 84 rabbit is the weirdest one ive laid hands on..
and yea, all gas rabbits ive worked on, one fuel pump, outside the tank.. down where the pump and filter are on an mk2..
« Last Edit: August 07, 2010, 02:13:34 pm by Rabbit on Roids »
Reply #8August 09, 2010, 08:46:29 pm
jaysen71581
  • 211
    Hagerstown, MD
« Reply #8 on: August 09, 2010, 08:46:29 pm »
Well im going to have spare parts left after this, right now i have a diesel NA pump, alternator bracket, waterpump housing, tranny from the 85 jetta td that went with the moter, 2 1.6 blocks and a completely redone head that was professionally rebuilt and milled...
I found what looks like a pump on the passenger side of the car infront of the rear tire, im cleaning pieces of the cars motor as i go so its taking me a longer time to put it back together.
