Author Topic: 2 questions  (Read 3034 times)
July 28, 2010, 11:48:40 pm
myvolkswagen
  • 96
2 questions
« on: July 28, 2010, 11:48:40 pm »
1. Should I replace all my con rod bolts if they were torqued but the engine never ran?
2. There is some rust on my cylinder walls after honing. Should I be worried about that?
Reply #1July 28, 2010, 11:58:25 pm
Re: 2 questions
« Reply #1 on: July 28, 2010, 11:58:25 pm »
I have reused quite a few in stock applications.
Rust-if it wipes off with wd 40 and a rag, no problem.
Reply #2July 29, 2010, 06:32:07 pm
myvolkswagen
  • 96
Re: 2 questions
« Reply #2 on: July 29, 2010, 06:32:07 pm »
So the con rod bolts will be fine? I wasn't sure because I heard they weren't to be reused. they were torqued to spec about 3 years ago but were never ran.
Reply #3August 03, 2010, 10:31:20 am
myvolkswagen
  • 96
Re: 2 questions
« Reply #3 on: August 03, 2010, 10:31:20 am »
Nobody has an answer to that? Don't really want to grenade my engine
Reply #4August 03, 2010, 11:01:40 am
Re: 2 questions
« Reply #4 on: August 03, 2010, 11:01:40 am »
The engine designer/manufacturer says they are a one-time-use bolt.  If you've torqued em and then loosened them they're done... regardless of whether the engine ran or not.   ;)
Being a conservative engineer-type, my answer is to agree with the much smarter brains in Germany... I use 'em once, and then pitch 'em.... for the few bucks it costs me.
On the other hand, many folks reuse 'em and never have any issues.   There's no real answer here other than your own comfort level... which is different for everyone.
Reply #5August 03, 2010, 03:14:52 pm
Re: 2 questions
« Reply #5 on: August 03, 2010, 03:14:52 pm »
I swear I read in the bentley that some of the first 1.6 and 1.5 had reusable con rod bolts. The later though for sure did not. ARP for around 100.00 is the cheapest as you can reuse them. At least you can reuse them until the stretch is too much which should take a lot.
Reply #6August 03, 2010, 04:53:32 pm
myvolkswagen
  • 96
Re: 2 questions
« Reply #6 on: August 03, 2010, 04:53:32 pm »
What do the stock bolts sell for from the dealer?
Reply #7August 03, 2010, 04:57:09 pm
Re: 2 questions
« Reply #7 on: August 03, 2010, 04:57:09 pm »
$2-$3 a piece I think. It depends what engine we are talking about though
Reply #8August 03, 2010, 07:17:34 pm
Re: 2 questions
« Reply #8 on: August 03, 2010, 07:17:34 pm »
Are the Con Rod bolts a place worth going to the more expensive ARP type bolts? I know the head bolts are a known weakness and worthwhile to replace, but are the con rod bolts typically stressed beyond stock bolts on these motors?
Reply #9August 04, 2010, 09:50:24 am
jack's lack
  • 275
Re: 2 questions
« Reply #9 on: August 04, 2010, 09:50:24 am »
Which engine is this? You will be able to find ARP bolts for the1.6L, but I was unable to get a part # for the AAZ when I did mine. The con rod bolts on the AAZ go through the cap and actually thread into the rod itself. Is not a separate nut and stud like ARP will try and sell you if you call. I had a number of frustrating correspondences with them trying to figure it out.
If you have the 1.6L I guess it depends on how hard you will be pushing the engine, and what gives you peace of mind, and of course the depth of you pockets.
1982 Rabbit diesel L 4 door
AAZ, K14, Giles pump, PD150 intake, P&P'd head, ceramic coated pistons, 2.5" stainless down pipe & exhaust. FK coils
My Build Thread
Reply #10August 30, 2010, 11:35:15 am
myvolkswagen
  • 96
Re: 2 questions
« Reply #10 on: August 30, 2010, 11:35:15 am »
its a 91 mf turbo diesel. So I went to the local dealer and they want to charge me $12 a con rod bolt. Is that right or are they trying to screw me cuz arp is essentially that price?! The nuts are reusable right?
Reply #11August 30, 2010, 06:56:58 pm
Re: 2 questions
« Reply #11 on: August 30, 2010, 06:56:58 pm »
bolts are reuseable too im pretty sure..
Reply #12August 31, 2010, 06:47:12 pm
myvolkswagen
  • 96
Re: 2 questions
« Reply #12 on: August 31, 2010, 06:47:12 pm »
I dont think they are. where does everyone get their replacement ones at?
Reply #13August 31, 2010, 07:04:17 pm
rallydiesel
  • 1880
Re: 2 questions
« Reply #13 on: August 31, 2010, 07:04:17 pm »
I just got mine from the dealer. Next time I remove the rods I will get ARP's cuz my bum is still tender from the dealer.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
