Author Topic: Tools by location thread  (Read 19440 times)
Reply #15December 11, 2011, 11:01:57 am
Re: Tools by location thread
« Reply #15 on: December 11, 2011, 11:01:57 am »
VCDS
Wheel bearing tools
Timing belt tools
intermediate shaft bearing tools.
Lots lots more
what tools are required to do wheel bearings?
Reply #16December 11, 2011, 10:41:09 pm
« Reply #16 on: December 11, 2011, 10:41:09 pm »
for me.. on car.. slide hammer to yank hub out.. snap ring pliers for the snap ring.. portable press tool with pieces to press it out via wrench/ratchet.. aka can do on car type of thing.. air chissel to knock inner race off hub.. use same press tool to reinstall hub..
other tools.. axle nut socket.. ball joint pinch bolt removal tools.. impact driver to remove set screw holding rotor to hub.. socket to remove caliper.. caliper carrier if you can..
now no portable press tool.. gotta have a press to remove the bearing and press hub in.. and the socket to remve upper strut from body so you do not screw up alignment.. and a socket/wrench for tie rod end..
Reply #17December 17, 2011, 04:54:21 pm
somedumbjerk
  • 71
« Reply #17 on: December 17, 2011, 04:54:21 pm »
triple square/12pt 6, 8, 10 an 12mm
idi timing kit
compression tester
engine stand  ;D
located in Palo Alto CA.
Reply #18January 25, 2012, 06:45:34 pm
Syncroincity
  • 727
« Reply #18 on: January 25, 2012, 06:45:34 pm »
Queens, New York
Engine hoist crane
Engine stand
Compressor & air tools; impact gun, air hammer, grinder etc
Tripple-square full set & most allens (also 17mm trans plug allen)
IDI timing tools & dial indicator
Spring compressors
Torque wrenches: click & deflection
Vanagon axle nut (46mm) socket & hammer tool
Injector socket
02 sensor sockets
Pickle fork
Ramps
Wire-feed MIG welder
Cylinder bore gauge
Cylinder hone (3-stone)
OBDII scan tool - generic, not vag-com
Fluke meter
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
Reply #19January 25, 2012, 07:56:21 pm
« Reply #19 on: January 25, 2012, 07:56:21 pm »
44505 area.. ne ohio... full shop w lift, vagcom.. tools.. mig and tig.. no tire machines though.. and bosses thought on retiring in the fall means i have no idea... he keeps talking tire machine though...
Reply #20March 06, 2012, 11:18:20 pm
oldpoopie
  • 46
« Reply #20 on: March 06, 2012, 11:18:20 pm »
VCDS
Wheel bearing tools
Timing belt tools
Lots lots more
Hub tamer elite lets me change wheelbearings without pulling the hub.
1985 jetta TD. It was free, and it shows. Down and dirty engine refresh made it run fairly well.... No leaks, except water into the cabin!
2001 golf Tdi. Heavy built ALH, soon to have a PD Frankenstein motor.
Reply #21March 09, 2012, 09:51:33 pm
pointynoggin
  • 93
« Reply #21 on: March 09, 2012, 09:51:33 pm »
Armstrong bc
timing tools
assorted engine work tools
1991 Jetta 1.6TD, Giles Superpump,
Reply #22April 12, 2012, 09:14:05 am
guy plain
  • 121
« Reply #22 on: April 12, 2012, 09:14:05 am »
any one around kamloops or close to....even vancouver have the timing tools for a 1.6 td? thanks in advance for any replys
Reply #23April 28, 2012, 08:17:49 am
92EcoDiesel Jetta
« Reply #23 on: April 28, 2012, 08:17:49 am »
Governor mod tool.  Queens NY. you are welcome to borrow it. local loan only, no mail.
This tool makes shimming the governor a breeze.
Reply #24April 28, 2012, 09:12:17 pm
billybobf
  • 318
« Reply #24 on: April 28, 2012, 09:12:17 pm »
florence oregon.
mig welder,
engine hoist
engine stand
cylinder boring bar
harbor freight compression tester and three stone cylinder hone.
soon to be pop tester, need an 8mm dial indicator to run the pump timing adapter I bought.
sure i have some other stuff. pressure washer.
