Is this the Blow Off Valve?
Topic: Is this the Blow Off Valve? (Read 3818 times)
July 19, 2010, 01:37:38 am
Robb
User+
July 19, 2010, 01:37:38 am »
Im told my GTD will probably have a blow off valve alongside the wastegate, Im not used to diesels having one, is this the correct unit?
If so please can someone explain how to take it out the equation so the wastegate is the only thing controlling boost, the pictures in the old thread are now broken links.
Thanks
July 19, 2010, 01:44:33 am
Robb
User+
Re: Is this the Blow Off Valve?
July 19, 2010, 01:44:33 am »
After removing it from the engine im 99% sure it is the factory BOV because of the way it works, however Im not a little unsure how to go about blocking up the huge hole removing it creates, what methods have people used?
July 19, 2010, 01:56:35 am
dave friday
July 19, 2010, 01:56:35 am »
stick a wine cork in it.
1992 1600 td syncro camper
July 19, 2010, 02:12:10 am
Robb
User+
July 19, 2010, 02:12:10 am »
Ive removed the spring and replaced it with a solid bolt and nipped it back up, theres no way this old thing is going to be creeping open now, stuck it back on the engine and jobs a goodun.
July 19, 2010, 06:23:02 am
July 19, 2010, 06:23:02 am »
Vendor section : Giles performance diesel sells a machined block off kit if you want.
Round 2
July 19, 2010, 09:32:48 am
July 19, 2010, 09:32:48 am »
I put a chunk of a broom handle in the hose connected to it, and then made sure the clamp was good and tight! I like the wine cork idea though...
July 19, 2010, 03:01:11 pm
July 19, 2010, 03:01:11 pm »
you'd need an enormous wine cork...
he is talking about the hole it leaves behind in the intake. Giles had actual plugs machined. the ID of the hole is like 2.25 inches... its not a wine bottle size hole.
I however used to have a wine cork jammed in my intake snokel that it left behind there. But its better to melt something to it like a piece of hose or something similar. plastic works. but so does replacing the snorkel with some big ABS piping.
Blue 2009 CR140 Jetta CBEA/CJAA. Malone stage 2. EGR/DPF/Exhaust-valve deletes. 2.5" open exhaust. ADP Turbo swap. 1-stage nitrous kit.
THROWN ROD
July 19, 2010, 03:36:53 pm
July 19, 2010, 03:36:53 pm »
they are talking about leaving the BOV there, just sticking a wine cork in the outlet that feeds the air back to the turbo intake.
