Author Topic: 91 golf 1.6NA, 90mm or 100mm driveshafts?  (Read 4486 times)
December 09, 2005, 06:44:46 pm
Black Smokin' Diesel
  • 656
« on: December 09, 2005, 06:44:46 pm »
As stated in the title, is there any way to know which diameter driveshafts I've got on my car?? I'd say 100mm since it's a late mk2 but I don't want to order two driveshafts that may be of the wrong size for my car.
Does anyone know?
Reply #1December 10, 2005, 03:16:44 am
Maarten
  • 339
« Reply #1 on: December 10, 2005, 03:16:44 am »
Only Mk2 16vs (and some GTI 8vs) have 100mm driveshafts.
Your 1.6D has 90mm for sure
Audi A3 TDI '98
VW cabby '79
VW T3 1.9TD '91
Reply #2December 10, 2005, 11:14:52 am
vwmike
  • 1158
« Reply #2 on: December 10, 2005, 11:14:52 am »
Actually most of the gas mk2's in north America had 100mm axles, but I don't think any of the diesels did.
Reply #3December 11, 2005, 05:17:43 pm
zyewdall
  • 393
« Reply #3 on: December 11, 2005, 05:17:43 pm »
Quote from: "vwmike"
Yeah. My Mk2 diesel rabbit has 100mms, because it was born as a gas GTI.  From what I understand the OEM diesel's were 90mm.
'89 Subaru 4x4 touring wagon
1976 Ford Sasquatch pickup
Reply #4December 12, 2005, 11:02:23 am
dubCanuck1
  • 279
    • http://www.canadubs.com
« Reply #4 on: December 12, 2005, 11:02:23 am »
90mm for ME and MF engines (aka NA/TD diesels).
Assuming you still have the stock tranny.
Reply #5December 12, 2005, 11:54:13 am
935racer
« Reply #5 on: December 12, 2005, 11:54:13 am »
All the original mk2 diesels I have seen have been 90mm axles.
Reply #6December 13, 2005, 04:21:17 am
  • 656
« Reply #6 on: December 13, 2005, 04:21:17 am »
Thanks a lot for the info guys. Is there any way to measure this without taking off the axles? I wanna be 100% sure.
Reply #7December 13, 2005, 07:11:24 am
dubCanuck1
  • 279
« Reply #7 on: December 13, 2005, 07:11:24 am »
Well, you could do the old school way. Grab a tape measure (for your waist), wrap it around the flange (the CV itself is slightly smaller). Then look at how large it is.
The circumference of the 100 mm axle should be 314+mm. The 90 mm axle should be ~282/283mm.
Reply #8December 13, 2005, 01:07:06 pm
Maarten
  • 339
« Reply #8 on: December 13, 2005, 01:07:06 pm »
Infcat, the 90mm axles are about 92mm.. the 100mms 98, so measure very precise ;)
I don't know the word in english:
I've got one that can span over the sides, so I can measure the axles without taking them off.
Audi A3 TDI '98
VW cabby '79
VW T3 1.9TD '91
Reply #9December 14, 2005, 03:51:10 am
  • 656
« Reply #9 on: December 14, 2005, 03:51:10 am »
Thanks a lot guys, I'll check that out!
Reply #10December 14, 2005, 11:28:37 am
fspGTD
  • 1529
« Reply #10 on: December 14, 2005, 11:28:37 am »
Maarten: those are called digital calipers.  It's amazing how widely available and inexpensive they are nowadays.
Jake Russell
