Author Topic: Smoke. Good/Bad?  (Read 6076 times)
June 15, 2010, 06:12:12 am
superbro
  • 45
Smoke. Good/Bad?
« on: June 15, 2010, 06:12:12 am »
Hey guys I was wondering if smoke is good or bad. I have my timing advanced a little and it never smokes. Should it? The only time it dose is on cold mornings.
2005 TDI Jetta Wagon 5 speed.
 Sold :'( 1983 Caddy 1.6 N/A 5 speed. Daily driver.
Reply #1June 15, 2010, 10:16:34 am
Re: Smoke. Good/Bad?
« Reply #1 on: June 15, 2010, 10:16:34 am »
smoke = wasted fuel.
Reply #2June 15, 2010, 01:39:17 pm
superbro
  • 45
« Reply #2 on: June 15, 2010, 01:39:17 pm »
Ok. But shouldn't it smoke a little? Like getting on the freeway? I'm trying to find out if I'm running a little lean.
Reply #3June 15, 2010, 09:34:21 pm
mystery3
  • 774
« Reply #3 on: June 15, 2010, 09:34:21 pm »
Anytime you take your foot off the accelerator your diesel is running "lean."  There is a lot of reading/research on this site regarding the IP, mods, timing etc. That said my 1.6 doesn't smoke except for a few seconds on cold starts but it is slow as hell.
Reply #4June 19, 2010, 10:44:00 pm
« Reply #4 on: June 19, 2010, 10:44:00 pm »
When your foot is not on the pedal, there is no fuel being injected. So feel safe, that engine breaking has no effect on mileage. ;)
It should smoke a little bit, Bentley calls for a light grey haze under WOT.
Reply #5June 20, 2010, 06:46:39 am
« Reply #5 on: June 20, 2010, 06:46:39 am »
diesels always run lean. even when you are blowing a black cloud out the back, its still running lean.
Reply #6June 20, 2010, 09:07:06 am
81 vw pu
« Reply #6 on: June 20, 2010, 09:07:06 am »
Fuel is still being injected when you take your foot off the throttle, otherwise the engine would die like turning off the key.
Reply #7June 20, 2010, 10:07:13 am
« Reply #7 on: June 20, 2010, 10:07:13 am »
No because the car is now driving the engine. If the pump were to continue injecting fuel it would not slow down. As the RPMs approach idle then the pump will slowly start injecting fuel so that the engine will maintain idle and not stall.
Reply #8June 21, 2010, 06:14:29 pm
Turbinepowered
  • 1206
« Reply #8 on: June 21, 2010, 06:14:29 pm »
If you increase fueling to the point of it smoking you might gain a little power, but you will pay the cost in fuel economy any time you play.  Blowing smoke is also an indication of high EGTs.  Even if EGTs are not dangerously high, under-fueled is ALWAYS better for engine longevity.
For diesels. I can't count how many times people have worried about being "too lean" with their first diesel... :D
Reply #9June 22, 2010, 07:37:52 am
« Reply #9 on: June 22, 2010, 07:37:52 am »
they are still lean, even with a black soot trail behind them.
