Author Topic: can we use this cam?  (Read 4115 times)
June 03, 2010, 06:21:52 pm
Reply #1June 03, 2010, 09:27:44 pm
MJF
  • 581
Re: can we use this cam?
« Reply #1 on: June 03, 2010, 09:27:44 pm »
Sure you can. That figure above shows only that 2,5 cam has a little more duration than 2,4 cam. Might want to check piston-valve clearance too.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #2June 04, 2010, 08:43:00 am
« Reply #2 on: June 04, 2010, 08:43:00 am »
the cam says it lowers the compression? how is this achieved? holding the valves open too long and letting some air get out?
Reply #3June 04, 2010, 05:19:52 pm
410
  • 581
« Reply #3 on: June 04, 2010, 05:19:52 pm »
A slight valve overlap would be my guess.
Reply #4June 04, 2010, 08:04:19 pm
« Reply #4 on: June 04, 2010, 08:04:19 pm »
that would be no good for boost..
Reply #5June 04, 2010, 08:45:41 pm
410
  • 581
« Reply #5 on: June 04, 2010, 08:45:41 pm »
 Why would that be an issue for boost??  It can only be a small amount of overlap anyway since the overlap happens when the piston is at tdc so very little room is available.  Do you think that you would actually lose enough boost out the exhaust to notice it?
I do think that this would be a good cam for the idi's imo.  The aaz cam I believe has a little more lift than the 1.6 cam which would be a cheaper upgrade.  I don't know if there would be a noticeable difference.
Reply #6June 05, 2010, 06:31:17 am
« Reply #6 on: June 05, 2010, 06:31:17 am »
i thought 1.6 cams were better for some reason having to do with emissions
Reply #7June 05, 2010, 06:38:01 am
« Reply #7 on: June 05, 2010, 06:38:01 am »
Reply #8June 05, 2010, 11:28:55 am
« Reply #8 on: June 05, 2010, 11:28:55 am »
TDI's have turbos and people running this cam most likely run higher than stock boost.
Reply #9June 05, 2010, 09:41:19 pm
AudiVWguy
« Reply #9 on: June 05, 2010, 09:41:19 pm »
I can't see the whole sheet. What cam is the yellow line?
Reply #10June 05, 2010, 11:29:34 pm
mystery3
  • 774
« Reply #10 on: June 05, 2010, 11:29:34 pm »
The yellow is the g60 cam.
Reply #11June 06, 2010, 07:02:48 am
« Reply #11 on: June 06, 2010, 07:02:48 am »
At the bottom of the picture there is a scroll bar. It kind of blends in with the taskbar in the picture though.
Reply #12June 06, 2010, 07:43:50 am
« Reply #12 on: June 06, 2010, 07:43:50 am »
so aaz is the better cam...
Reply #13June 06, 2010, 07:49:45 am
« Reply #13 on: June 06, 2010, 07:49:45 am »
so what cam is better, this one or dr. diesels
Reply #14June 06, 2010, 08:45:09 am
macka
  • 957
« Reply #14 on: June 06, 2010, 08:45:09 am »
I'd personally go with Docs cam, as it is purpose designed, but whichever you want to go with is ultimately your decision.
Quote from: Vincent Walden
