Author Topic: high power dream, transmission impossible?  (Read 11515 times)
Reply #30May 25, 2010, 08:14:21 pm
Pat Dolan
  • 163
Re: high power dream, transmission impossible?
« Reply #30 on: May 25, 2010, 08:14:21 pm »
Yeah, the 2.0/2.4/2.5 inline 5 cyl engines are Audi bolt pattern, not VW 4 banger.   What tends to fool people is that there are some gearboxes out there with BOTH bolt patterns (all in Audis I think).
For Nintendo's transverse 4 cyl, you want a TDI trans from a later model MkIV (easiest, plentiful) or if you want to make big power and have lots of gears, a DRW 6 speed - which is already geared to diesel revs.  I don't think you will be at 7 grand, but if you are stopping even at 6, gearing of gasser trans won't be that bad (and there are a LOT of them around).  Forget the 020:  it is very torque/abuse limited as others have pointed out.  Also getting harder to support.  If you go with a cable shift 02A, there are lots of clutch options, starting with VR6 gasser flywheel/clutch setup (straight bolt in to 5 speeds) to many aftermarket performance setups.
« Last Edit: May 25, 2010, 08:18:08 pm by Pat Dolan »
lifetime VW enthusiast, racer, fixer, addict, etc.
'03 TDI Variant, MkII Golf Country, Mk1 and II Scirocco (gassers), a Vanagon aircooled, an Audi 2.0 TD waiting to become a Porsche TD (in my M471 924), FLD120/DDEC IV, Ford 7.3/450, Iveco D220 and some 6D14T Mitsus and a few more.
Reply #31May 25, 2010, 10:10:49 pm
MJF
  • 581
« Reply #31 on: May 25, 2010, 10:10:49 pm »
VR6 flywheel does not bolt to 4cyl, youŽll need 1Z or 2,0 gasser Passat/Corrado flywheel. Clutch will fit to both.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #32May 25, 2010, 10:30:59 pm
NintendoKD
  • 931
    dnahtasinoivilboeraweb
    • myspace page
« Reply #32 on: May 25, 2010, 10:30:59 pm »
sweet, good info guys.  I plan to have the redline at or about 7k that doesn't mean it actually be just that.  I don't really know that much about the transmission side of the house or exactly why and how the diesel tranny differs from the gasser, I can only assume, as the gassers re much higher naturally, that that is the only difference but not sure.  This one for sale seems pretty promising but I don't want to end up with a bum transmission for this most auspicious of builds.  Everything needs to be perfect, and that is the number one reason why I started this thread.  Keep the good advice coming.
Thanks,
Kevin
Reply #33May 26, 2010, 08:44:11 am
« Reply #33 on: May 26, 2010, 08:44:11 am »
why dont you just get a pile of parts together and start building something? think the old school hot rodders had a forum to tell them how to put their cars together? i think not..
you claim you can do anything, so, i wanna see a car start developing here. start building, then drive it. it will be appearent what needs to be upgraded, cause its gonna be whatever breaks first..
you never get to build the car one time, then finish it, then never touch it again, it doesnt work like that. when you own a VW, you work on it damn near every day. sometimes a few times a day.
Reply #34May 26, 2010, 11:10:29 am
« Reply #34 on: May 26, 2010, 11:10:29 am »
LOL, you got that right.  I'm a moron for having 4 of them.  :P
Reply #35May 26, 2010, 11:13:14 am
« Reply #35 on: May 26, 2010, 11:13:14 am »
Just to clarify, I was talking about the new-ish rabbit/Jetta 2.5 that came out in the MkVI- it's a normal 4-cylinder bolt pattern.  Getting it to work on a longitudinal dual-bolt patten Audi trans requires trimming of the gearbox bellhousing but that does not apply to FWD.
And, there is no difference between the diesel-specific transmissions and gasser transmissions, other than the gear ratios.  They are internally/externally exactly the same.
Reply #36May 26, 2010, 11:54:04 am
NintendoKD
  • 931
    • myspace page
« Reply #36 on: May 26, 2010, 11:54:04 am »
I wholeheartedly disagree, I am not Thomas Edison >:(, nor do I have his resources ::).  I want to plan it, do it right, and do it right the first time. 8)  My Machinist has brain cancer and will likely never be able to have steady hands again so Now I need a new Machinist on top of every other challenge that I face.  Thanks,
Kevin
« Last Edit: May 26, 2010, 11:59:45 am by NintendoKD »
Reply #37May 26, 2010, 11:55:48 am
NintendoKD
  • 931
    • myspace page
« Reply #37 on: May 26, 2010, 11:55:48 am »
sorry, and thanks for clarifying.  My limited knowledge of transmissions had me confused
thanks,
Kevin
Reply #38May 27, 2010, 12:20:14 am
« Reply #38 on: May 27, 2010, 12:20:14 am »
the more the merrier!!!
i have a couple 80 (2dr & 4dr), a few 81 (two 2dr & 4dr), an 82, all rabbits, an 85 GTI, 86 Golf, 92 jetta, 96 jetta and an 83 audi.
wow.....
this is the first time ive sat down and realized i own 11 vws.. and only 3 driveable right now.
Reply #39May 27, 2010, 12:42:12 pm
« Reply #39 on: May 27, 2010, 12:42:12 pm »
wow.....
I have the same thing with vintage bicycles... :P  Maybe 3 1/2 rideable out of about 15
Reply #40May 30, 2010, 10:52:12 am
NintendoKD
  • 931
    • myspace page
« Reply #40 on: May 30, 2010, 10:52:12 am »
well I bought that one for 600.00 shipped now I just have to repair the small dent in the housing and off I go to th driveline specialists to make a custom driveline. ;D
Reply #41May 30, 2010, 02:51:19 pm
smutts
  • 720
    ClackClackClackClackClack
« Reply #41 on: May 30, 2010, 02:51:19 pm »
Have VW seen the light and stopped using those suicide rivets on the crownwheels? ???
Reply #42May 30, 2010, 06:35:15 pm
NintendoKD
  • 931
    • myspace page
« Reply #42 on: May 30, 2010, 06:35:15 pm »
dunno :-[
Reply #43May 30, 2010, 07:20:49 pm
« Reply #43 on: May 30, 2010, 07:20:49 pm »
What did you buy?
Also, after talking to brokevw and learning from him, the problem transmissions were the MKII and up 020. The MKI 020 had rivots too, but they were harder than a woodpeckers lips. Brokevw said you don't want to try and drill those out. Afterwards from what I gather the ring gear is held on better.
Reply #44May 30, 2010, 11:48:08 pm
NintendoKD
  • 931
    • myspace page
« Reply #44 on: May 30, 2010, 11:48:08 pm »
it's an 02q out of the next generation car (mk5 instead of mk4).  The transmissions are largely the same for your use, here's a link talking about the differences: http://www.sqsracing.com/files/fs_files/productdetails/200/manual-02m-q_55.pdf
Here's a link to the for sale thread.   He said he'd definitely take 500.
http://forums.vwvortex.com/showthread.php?4841340-2007-O2Q-Trans-4cl-6MT-30K-miles-600.00-w-shifter-starter
paid 600 shipped to a buisness address on base
