Author Topic: high power dream, transmission impossible?  (Read 11487 times)
Reply #15May 24, 2010, 09:27:42 am
Re: high power dream, transmission impossible?
« Reply #15 on: May 24, 2010, 09:27:42 am »
the rollers start skipping around 7-7.5k rpms. they simply cant go any higher than that. kev, why dont you just fit a inline P pump off a 4 banger cummins or mercedes engine? that would give way more than enough fuel. its not gonna be even remotely close to bolt on and go, but you should be able to make something work if your gonna graft this into a mr2.
Reply #16May 24, 2010, 10:49:20 am
bagpipegoatee
« Reply #16 on: May 24, 2010, 10:49:20 am »
I have a friend with an 02m (6 speed, 2 wheel drive) out of an 03 20th anniversary gti for sale, with shifter box/cables/clutch/everything and is asking 500 I think.   Shipping would be the hard part.   This is the tougher of all the transmissions listed in this thread.
Reply #17May 24, 2010, 11:26:46 am
« Reply #17 on: May 24, 2010, 11:26:46 am »
I wonder if stronger springs inside the pump would counteract this, as heavier valve springs would in a head?
Reply #18May 24, 2010, 05:04:26 pm
macka
  • 957
« Reply #18 on: May 24, 2010, 05:04:26 pm »
maybe but how would heavier springs affect the initial fueling?
Quote from: Vincent Walden
Reply #19May 24, 2010, 05:05:52 pm
« Reply #19 on: May 24, 2010, 05:05:52 pm »
yeah i came to that thought afterwords... I have no idea, I'm guessing a higher internal pump pressure would be needed?
Reply #20May 24, 2010, 05:16:49 pm
« Reply #20 on: May 24, 2010, 05:16:49 pm »
the springs are closely matched to the pump head assy. thats why bigger pumps dont run well when people swap in 10 or 11mm heads and use 9mm springs instead of the tougher springs that are set up for the 11mm head.
Reply #21May 24, 2010, 10:11:43 pm
NintendoKD
  • 931
    dnahtasinoivilboeraweb
    • myspace page
« Reply #21 on: May 24, 2010, 10:11:43 pm »
ooh!  me want :o PM sent
Reply #22May 25, 2010, 08:39:05 am
« Reply #22 on: May 25, 2010, 08:39:05 am »
and an 02M fits on a diesel bell housing this old?
Reply #23May 25, 2010, 08:58:13 am
NintendoKD
  • 931
    • myspace page
« Reply #23 on: May 25, 2010, 08:58:13 am »
it's an 02q out of the next generation car MK5 should bolt up still right?  this is also a cable shift tranny and will ork with the cable shift setup of the spyder
Reply #24May 25, 2010, 09:12:48 am
macka
  • 957
Reply #25May 25, 2010, 10:09:22 am
« Reply #25 on: May 25, 2010, 10:09:22 am »
All transverse VW 4-cylinder bolt patterns are the same.  4-speed, 5-speed, and 6-speed.  That's all 4-cylinder engines too, 8v, diesel, TDI, 16v, 1.8t, and even the 2.5 5-cylinder.
There are some differences with flywheel mounting and clutch splines but that's easy stuff compared to everything else that's needed with a tranny swap.
Reply #26May 25, 2010, 01:51:30 pm
« Reply #26 on: May 25, 2010, 01:51:30 pm »
i thought the 2.5 was actually different,  josh at nls had to do some weird stuff to make it work in the rabbit, he did use an 020 but it wasn't a direct bolt on
Reply #27May 25, 2010, 05:39:05 pm
NintendoKD
  • 931
    • myspace page
« Reply #27 on: May 25, 2010, 05:39:05 pm »
what stuff has to be done to the flywheel tranny spline?  I plan to lighten whatever flywheel I use to a rediculous degree so this info in advance would be of tremendous use now.
Reply #28May 25, 2010, 06:27:32 pm
« Reply #28 on: May 25, 2010, 06:27:32 pm »
you just gotta bolt the appropriate flywheel/clutch/pressure plate on the engine that is particular to that transmission. shouldnt have to modify the input shaft splines at all...
Reply #29May 25, 2010, 06:47:58 pm
« Reply #29 on: May 25, 2010, 06:47:58 pm »
So you're saying the added force needed to shove the plunger would make the roller cage fight the internal pressure. I think it would but I bet that could be fixed with bumped up internal pressure.
