Help with Vanagon engine mount dimensions...
Topic: Help with Vanagon engine mount dimensions... (Read 4177 times)
April 21, 2010, 08:20:08 pm
Luckypabst
April 21, 2010, 08:20:08 pm »
Regarding the later style rubber Vanagon engine mounts, I'm looking for a few dimensions.
First, I need to know the distance from the center of the 10mm center bolt to the
inboard
side of the metal casing.
Next I'd like the dimension from the center of the 10mm bolt to the center of the locating nub.
Finally, if someone has it, I'd like to know how far the head of the larger (12mm?) mounting bolt protrudes beyond the edge of the metal casing.
The attaced photo might help illustrate what I'm after...
Thanks
Chris
'82 TD Westy
'81 NA Caddy
April 21, 2010, 10:34:30 pm
Luckypabst
Re: Help with Vanagon engine mount dimensions...
April 21, 2010, 10:34:30 pm »
Later ones...
'82 TD Westy
'81 NA Caddy
April 22, 2010, 07:05:48 am
monkey magic
April 22, 2010, 07:05:48 am »
May have these off at the weekend on mine, if so I'll take some measurements for you.
MM
mTDi syncro
April 22, 2010, 08:34:29 am
Luckypabst
April 22, 2010, 08:34:29 am »
Thanks fellers...
Much appreciated! I can't bring myself to spend $60 just to take a couple of measurements.
Chris
'82 TD Westy
'81 NA Caddy
April 26, 2010, 10:29:50 pm
Luckypabst
April 26, 2010, 10:29:50 pm »
Any luck, MM?
'82 TD Westy
'81 NA Caddy
April 27, 2010, 02:22:15 am
CdnVWJunkie
April 27, 2010, 02:22:15 am »
I'm sure I've got some loose ones kicking about here. I'll look later today.
April 27, 2010, 06:45:53 am
monkey magic
April 27, 2010, 06:45:53 am »
now i feel like a bit of a donkey, forgot all about this until finding the thread again just now
sorry aboot that, I had the engine out too so I could have done this easily!!
I have an engine mount in the cellar, I could measure centres on the stud hole to the nub locating hole from that?
Is the main stud not central on the whole piece?
mTDi syncro
April 27, 2010, 08:27:48 am
Luckypabst
April 27, 2010, 08:27:48 am »
I'm not really sure... I'm kinda betting that VW used the same outer shell as the early style mounts, turned 90 degrees with changes only to the internal part of the mount. I just need to verify one way or the other...
Thanks
Chris
'82 TD Westy
'81 NA Caddy
April 27, 2010, 12:04:54 pm
Powered by Spearco
April 27, 2010, 12:04:54 pm »
I figured out that Audi A4's and A6's w/ manual trans. use the same mount for the trans.
So maybe there is some better derometer for those mounts?
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
April 28, 2010, 09:21:56 am
Luckypabst
April 28, 2010, 09:21:56 am »
Last attempt...
Anybody?
'82 TD Westy
'81 NA Caddy
April 28, 2010, 11:17:33 am
monkey magic
April 28, 2010, 11:17:33 am »
Chris,
I just measured the bracket I have, dim B is 25mm. I would guesstimate that dim A is 35mm.
Hope this helps, sorry again i forgot when I had the engine out
What is your last question about the 12mm head, I dont entirely understand? Sounds like you are just asking for the depth of the bolt head??
Last Edit: April 28, 2010, 11:20:28 am by monkey magic
mTDi syncro
Reply #11
April 28, 2010, 11:57:17 am
Luckypabst
Reply #11 on:
April 28, 2010, 11:57:17 am »
Thank you much!
Just so we're on the same page - you're measuring the two holes in the aluminum "arm", correct? This would be the later arm that has the small locating hole drilled inboard of the larger mounting hole, as well as the two little locating tabs extending off toward the front?
Regarding the other question, I'm curious how much clearance is required to accommodate the head of the mounting bolt beyond the edge of the rubber mount. I can estimate this if all else fails.
Chris
'82 TD Westy
'81 NA Caddy
Reply #12
April 28, 2010, 04:31:25 pm
monkey magic
Reply #12 on:
April 28, 2010, 04:31:25 pm »
Not sure about the 2 tabs, Ill take a looky again tomorrow, but yes hole wise. Yup its the later style (1990).
I see what you mean with the bolt bit now, I can look on my van in the morning and check that out no probs (if i remember!
mTDi syncro
Reply #13
April 28, 2010, 06:10:01 pm
Luckypabst
Reply #13 on:
April 28, 2010, 06:10:01 pm »
Cool deal...
I'm not worried about the two tabs.
It's much appreciated!!
Chris
'82 TD Westy
'81 NA Caddy
Reply #14
April 30, 2010, 12:29:38 am
monkey magic
Reply #14 on:
April 30, 2010, 12:29:38 am »
didnt go near the van yesterday cos it was raining, I'll have a look this morning (uk morning!) for you chris.
mm
mTDi syncro
