VWDiesel Blog
Facebook Group
VWD on Twitter
For Sale/Looking For
Parts for Sale/Wanted
WTB: diesel tach to fit vanagon
Topic: WTB: diesel tach to fit vanagon (Read 5842 times)
April 20, 2010, 05:34:33 pm
go.jolly
Newbie
April 20, 2010, 05:34:33 pm »
hello,
i need a diesel tach(the one with fuel and coolant on the bottom) to fit a'86 vanagon please.
like the one in the link
http://www.westyventures.com/images/curtstdisyncro%20104.jpg
thanks
shaun d
shaun d
April 20, 2010, 08:09:16 pm
Re: WTB: diesel tach to fit vanagon
April 20, 2010, 08:09:16 pm »
Have you looked on The Samba ?
April 21, 2010, 12:01:31 am
Kudagra
April 21, 2010, 12:01:31 am »
The clusters are pretty much modular. You can swap around tachs, clocks and speedos pretty easy. I noticed the speedo tops out at 100 and has a 1600 above the MPH. If I remember right that number is its calibration. Notice the gassers read one number and some later gasser 16v equipped cars sometimes read a different number. I bet thats just a regular Mk2 Jetta TD tach. The blue film is probably different as well..but the tach only needs a few wires that could be inserted into it through the film.
There is a way around everything...well..all but death and taxes.
Turbo boost libido and passive restraints
And as of yet I haven't heard even a single complaint
I've got the tools of the trade and a fuel injected heart
Efficiency is beautiful, efficiency is art
April 21, 2010, 01:59:31 am
blackdogvan
April 21, 2010, 01:59:31 am »
I run a 86' gasser vanagon tach with a dakota digital box. works great for me but not all vanagon tach's take the dd signal. with your 86 van you might want to try a dd box. I have a spare one... pm me if your interested.
1991 Vanagon 1.9 mTDI
April 21, 2010, 07:46:40 am
go.jolly
Newbie
April 21, 2010, 07:46:40 am »
thanks for the info,
-this type of tach comes up on the other forums sometimes and i'm keep-in my eye open, if you know of something else please let me know
-the tach in the link probably came from a Mk2 jetta/golf TD and is in a syncro cluster(1600 calibration)
-i need the tach to go into a syncro mtdi, so i need the w signal tach and i have heard the dd may not work
thanks
shaun d
April 21, 2010, 10:06:13 pm
Syncroincity
April 21, 2010, 10:06:13 pm »
I did mine with the tach from a '86 Jetta diesel. You need the one, as you noted, with the gas & temp gauge on the bottom, and "diesel 2.22" printed on the face. Very easy swap, once you find the right gauge. You have to pull the needle straight up off the hub; it may come off easy, it may not, just be careful. Simply hook the blue tach drive wire already in the van to the "W' terminal of the alternator, and you're good.
I took the opportunity while I had it open to paint all the needles day-glo orange, really makes them pop.
Here's a .jpg of the center warning lite icon panel... you can print this out on acetate, cut one out and drop it in your cluster. The glow-plug trace is already present on the ribbon cable, if you choose to use it. Right-click & save to your pc, then print it out; it will be sized correctly.
Last Edit: April 21, 2010, 10:10:31 pm by Syncroincity
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
April 22, 2010, 07:55:34 am
go.jolly
Newbie
April 22, 2010, 07:55:34 am »
thanks for the info on the year and for the swap tech.
i'll try the day-glo
i've been sitting on some dv cluster's w/clocks, so i have the icon panel, thanks i hope others are able to use that
now i just need to find a cluster, i know there around here some where
thanks
shaun d
April 27, 2010, 09:14:34 pm
go.jolly
Newbie
April 27, 2010, 09:14:34 pm »
still looking for a tach.
any leads would be great.
thanks
shaun d
May 05, 2010, 11:10:18 am
go.jolly
Newbie
May 05, 2010, 11:10:18 am »
still looking
thanks
shaun d
May 08, 2010, 05:38:22 am
Syncroincity
May 08, 2010, 05:38:22 am »
Patience, young padawan.
I waited for about 3 months for one to show up. Make sure you check here & Samba every day, they go quick when they do pop up.
JC McCavitt
'98 Jetta Wolfie
May 19, 2010, 01:55:04 am
go.jolly
Newbie
May 19, 2010, 01:55:04 am »
still looking
shaun d
Reply #11
May 28, 2010, 12:58:05 pm
go.jolly
Newbie
Reply #11 on:
May 28, 2010, 12:58:05 pm »
still searching, would love any leads
thanks
shaun d
