Author Topic: oil control rings  (Read 2782 times)
April 15, 2010, 05:10:55 pm
ffgb
  • 244
oil control rings
« on: April 15, 2010, 05:10:55 pm »
While I was setting up the Grant oil control ring in my motor, the piston just slid down the cylinder and the oil control ring hit the ground and split into 2 pieces.  I have the Mahle oil control rings that came with the the oversized pistons and was wondering if there is that much of difference in the two oil control ring designs?
I notices that the Grant oil control rings just cleared .010in and the Mahle just cleared .016.  I know both are within spec, but I will be using the Grant 1st and 2nd ring, I just don't know if I should be using the Mahle oil control ring or should I order another set of Grant rings so I could use there oil control rings.
Please Help!
Reply #1April 15, 2010, 06:34:49 pm
Re: oil control rings
« Reply #1 on: April 15, 2010, 06:34:49 pm »
I would just measure them all and see which one has the best fitment and go with it. The oil rings on the Mahle I have heard aren't that bad.
Reply #2April 16, 2010, 02:13:47 am
Mark(The Miser)UK
  • 1557
« Reply #2 on: April 16, 2010, 02:13:47 am »
Hi,
If you don't mind me asking; how are you, [or anyone] finding those currently discounted Grant rings? I'm about to order some. Postage to the UK is crippling, but even so , if they are  fine, then still far cheaper than UK stuff...
Thanks.
Mark-The-Miser-UK
Reply #3April 16, 2010, 06:27:28 am
ffgb
  • 244
« Reply #3 on: April 16, 2010, 06:27:28 am »
I found them at autohausaz.com.  The price is for all 4 cylinders.
Reply #4April 16, 2010, 09:16:59 am
  • 3468
    • McScrubbins Body Wash
« Reply #4 on: April 16, 2010, 09:16:59 am »
yes im running the same rings and i accidentally ordered 4 times too many. Hahahha
SO i actually have a spare set if you're interested? pm me and we'll see if it's cheaper for me to ship from the west coast of canada?
Reply #5April 16, 2010, 04:18:51 pm
ffgb
  • 244
« Reply #5 on: April 16, 2010, 04:18:51 pm »
Thanks, but I managed to get an extra oil control ring through Grant.  It was mailed out today, otherwise I would've purchase a set from you.
Reply #6April 16, 2010, 06:03:34 pm
Mark(The Miser)UK
  • 1557
« Reply #6 on: April 16, 2010, 06:03:34 pm »
So what's the quality like?
Do they need filing to get to spec?
Thanks
Mark-The-Miser-UK
Reply #7April 16, 2010, 08:07:16 pm
ffgb
  • 244
« Reply #7 on: April 16, 2010, 08:07:16 pm »
The rings are great quality.  The first ring end gap was right at the minimum.  The second ring I have to file to make it to the minimum.  Also, the second ring has a unique undercut bevel shape to it.  The oil control ring end gap was right at the minimum.  Compared to the Mahle rings that came with the pistons, the 1st ring looked the same.  The Mahle second ring was a standard shape ring, just like the 1st ring.  The Mahle oil control ring didn't seem as robust as the Grant ones.  The spring tension of the oil control ring on the Mahle was slightly less than the Grant, also the end gap on the Mahle was right at the maximum.  Hope this helps, this is all that I can compare them too.
Reply #8April 16, 2010, 09:14:31 pm
maxfax
  • 2126
« Reply #8 on: April 16, 2010, 09:14:31 pm »
Agreed..  I've installed several sets of Grant rings..  Always well within spec, and so far they've been holding up great... I have them in both of my Rabbits..   About 140,000 miles (225,000kms?) on one and around 195,000 miles (315,000kms?) on the other..   Neither engine has been re bored so there was some cylinder wear to begin with, but oil consumption has been next to nothing and compression is about 450psi (31 bar) as well...
Reply #9April 17, 2010, 07:23:09 am
Mark(The Miser)UK
  • 1557
« Reply #9 on: April 17, 2010, 07:23:09 am »
Great, I'll buy some then. Just gotta find a way of getting them through the dust cloud ;D
Mark-The-Miser-UK
