Author Topic: is it possible to replace IP dist. head to pump housing seal on car  (Read 5729 times)
April 11, 2010, 10:52:26 pm
vfr750
  • 6
My IP on my 92 NA Golf is leaking at the point where the distributor head joins the pump body.
I was wondering if anyone's had luck with changing the seal without removing the pump or will a crapload of parts fall outta the pump if i try this?
Is there anything i should be careful of when i do this?
Anyone know a good source for the seals in the Mississauga/Toronto area (the Bosch warehouse is 2 minutes away from me, do they sell 'em)
Thanks
Reply #1April 12, 2010, 01:52:39 am
anto
Re: is it possible to replace IP dist. head to pump housing seal on car
« Reply #1 on: April 12, 2010, 01:52:39 am »
People have done it and there is a guide to doing it somewhere.
However i would always take the pump off the car in order to change seals.
Reply #2April 12, 2010, 06:42:16 am
arb
« Reply #2 on: April 12, 2010, 06:42:16 am »
Yes it is possible and if done correctly there is absolutely no risk of damage, but if done incorrectly it can wreck the pump.  I've posted links quite a few times.  Search is your friend.  DON'T USE THE CRUSTY CRANK OR DIESELGEEK METHODS!!  They don't safeguard against ruining the pump.
Follow Adrew's details exactly and it will work !  I tried to follow his, but as I loosened the 4 cap screws, I let them come out a bit too far and was interrupted by the dinner bell. When I came back out 30 minutes later, the head springs had pushed the head a bit too far off the body and the shaft came out of alignment, so I had to remove the IP completely. Its now waiting a rebuild as I had several spares that were much easier to swap the seals on the bench - this time following his details w/o delays.
Reply #3April 12, 2010, 08:48:02 am
« Reply #3 on: April 12, 2010, 08:48:02 am »
i did it once and ruined my pump. had to take it most of the way apart to fix the pump head that i snapped.
Reply #4April 12, 2010, 08:52:56 am
vfr750
  • 6
« Reply #4 on: April 12, 2010, 08:52:56 am »
Gonna try libbybapa's method posted here h**p://www.vwdieselparts.com/forum/viewtopic.php?t=5311 and see how it goes.
What's the difference between seal kit DGK-121 or DGK-126?
Reply #5April 12, 2010, 09:14:34 am
« Reply #5 on: April 12, 2010, 09:14:34 am »
oh hell no, i didnt know crap about pumps, took the pump head out, re sealed it, then when i tried putting it back together, i broke the pump head. then after i broke that, the rollers fell out of the cage. so then i took it off, reinstalled the rollers and put a new pump head on it. still works...
Reply #6April 12, 2010, 12:29:16 pm
arb
« Reply #6 on: April 12, 2010, 12:29:16 pm »
You didn't keep constant pressure on the plunger, did you?
:-D  I had until dinner time, then it looked like the cast iron head was fused to the aluminum body, not realizing the O-ring was all that was holding it together - thus keeping the constant pressure until it let go. I understood to not even try to put it back together at that point w/o a full tear-down.
Reply #7April 12, 2010, 07:34:52 pm
vfr750
  • 6
« Reply #7 on: April 12, 2010, 07:34:52 pm »
Went to Sharma Diesel in Mississauga to get a seal kit. The guy there told me no need for the kit if all i'm gonna do is replace the o-ring. He gave me the o-ring for free!!! so i figured i'd give him some recognition. BTW he had this smug smirk on his face, and said he doesn't know of anyone who has done the seal replacement on-car successfully without trashing the IP. Soooooooo the gauntlet has been dropped 8) Gonna try and tackle it later this week. Thank God its biking season. At least i can get to work on the ol Honda ;D
Reply #8April 12, 2010, 07:36:27 pm
« Reply #8 on: April 12, 2010, 07:36:27 pm »
Clean the outside of your pump well, follow Andrew's instructions slowly and carefully, and then take the old o-ring back to your supplier and tell him to hang it on *his* wall.  ;)
Reply #9April 13, 2010, 02:34:17 pm
« Reply #9 on: April 13, 2010, 02:34:17 pm »
y.  its not that much work to remove it
Reply #10April 15, 2010, 10:54:47 am
« Reply #10 on: April 15, 2010, 10:54:47 am »
just pick up the drivers side of the car and set it on the passenger side. then none of the rollers will fall out of the pump.. lmfao...
Reply #11April 15, 2010, 03:02:53 pm
dieselweasel
  • 312
« Reply #11 on: April 15, 2010, 03:02:53 pm »
FWIW, I bought a distributor head o-ring from Giles and he too was doubtful that I could do the reseal successfully with the pump in-car.  Followed Andrew's instructions and it went off without a hitch.
Reply #12March 14, 2011, 11:36:04 pm
« Reply #12 on: March 14, 2011, 11:36:04 pm »
Thread returns from dead  for great success.
Looks like some of my fuel return geysers need a bit of work.
