Author Topic: VNT turbo on a JX manifold  (Read 12674 times)
April 04, 2010, 02:49:50 pm
  • 1739
« on: April 04, 2010, 02:49:50 pm »
I am thinking of going the TDI route for my transporter but to save some time and energy i'd like to use a JX manifold i already have so i don't have to fabricate a new l/s engine mount. So that's the question, has anybody tried to fit one to the JX manifold which came on Vanagon diesels.
Reply #1April 04, 2010, 03:47:05 pm
  • 1739
Re: VNT turbo on a JX manifold
« Reply #1 on: April 04, 2010, 03:47:05 pm »
I have to admit here that i'm being kinda lazy and i know that they won't actually bolt up easy, but i was wondering if it was easy, a bit of fabrication and welding, or a real pain.
Reply #2April 04, 2010, 04:49:00 pm
« Reply #2 on: April 04, 2010, 04:49:00 pm »
Change out of your pink long johns for some work clothes and go take a look :P
Do you have any pictures of this JX manifold's bolt pattern?
Reply #3April 04, 2010, 08:24:25 pm
  • 1739
« Reply #3 on: April 04, 2010, 08:24:25 pm »
the problem is that if i lie down to look, i'll want to stay there and take a nap.
i think it's   an isosceles  trapizoid. There are other manifolds like it but not sure/too lazy to figure it out which ones right now.
Reply #4April 05, 2010, 11:07:16 am
blackdogvan
  • 574
« Reply #4 on: April 05, 2010, 11:07:16 am »
1991 Vanagon 1.9 mTDI
Reply #5April 05, 2010, 12:47:59 pm
« Reply #5 on: April 05, 2010, 12:47:59 pm »
im almost for positive that its the same flange that the rabbit/jetta diesel turbos use. and i know of no VNT's that have that flange on them, its kinda a VW only thing from what ive seen.
Reply #6April 05, 2010, 01:16:03 pm
  • 1739
« Reply #6 on: April 05, 2010, 01:16:03 pm »
If i remember right [ that doesn't always happen ] the TDI VNT is a complete unit with the turbo housing. Without having one in front of me I'm wondering if there is enough meat between the manifold collector and the turbo's exhaust inlet to cut and weld up a matching flange.
Reply #7April 05, 2010, 01:16:44 pm
  • 1739
« Reply #7 on: April 05, 2010, 01:16:44 pm »
Which model turbo would that be?
Reply #8April 05, 2010, 01:18:47 pm
truckinwagen
  • 1895
« Reply #8 on: April 05, 2010, 01:18:47 pm »
the vw vnt has an integrated manifold, but it should be possible without too much work to cut the turbo off the manifold and weld a flange on.
all the vw TD turbos(except the T3) use the trapezoidal flange, K14, K24, T3 etc...
83 Opel Kadett Diesel
Reply #9April 05, 2010, 01:35:07 pm
blackdogvan
  • 574
« Reply #9 on: April 05, 2010, 01:35:07 pm »
Not all the VNT's VAG used are integrated with the exhaust mani, Passat TDI ones for example. Find one tho...
Reply #10April 05, 2010, 01:37:53 pm
truckinwagen
  • 1895
« Reply #10 on: April 05, 2010, 01:37:53 pm »
true, I guess I should have said "the vast majority of vw vnt's"
the non integrated ones are really hard to find, it would be easier and cheaper to cut and weld an integrated one.
and what bolt pattern are the passat ones? not the trapezoidal I am sure...
Reply #11April 05, 2010, 07:00:17 pm
blackdogvan
  • 574
« Reply #11 on: April 05, 2010, 07:00:17 pm »
I don't know about the passat ones shape... euro ebay sites are the best bet.
No chance of a 8v t25 gasser mani with an adapter plate fitting?
Reply #12April 05, 2010, 08:58:13 pm
« Reply #12 on: April 05, 2010, 08:58:13 pm »
This: http://www.volkswaparts.com/VNTTurboGasket.htm is the gasket it uses.
Reply #13April 06, 2010, 04:51:37 am
myke_w
  • 1099
« Reply #13 on: April 06, 2010, 04:51:37 am »
The vnt off the 04-05 TDI passat is also called a gt1749 VA, they used them here and in Europe on several motors.
Reply #14April 06, 2010, 05:34:29 pm
4wheeler
« Reply #14 on: April 06, 2010, 05:34:29 pm »
Where does one get a euro style VNT 17?
Whats typically the price tag on them?
