Author Topic: KKK turbo  (Read 6652 times)
March 20, 2010, 04:16:26 pm
dennis
  • 311
KKK turbo
« on: March 20, 2010, 04:16:26 pm »
This KKK turbo has the waste gate with the cooling cast cooling fins. Can anyone tell me what it is??
Uneducatedly
Dennis
1980 Caddy TD (Always in progress)
1983 Volvo 245 D24 NA Building D24T
1980 Air-cooled Westy
1956 F100 (What to do???))
Reply #1March 20, 2010, 04:19:46 pm
Re: KKK turbo
« Reply #1 on: March 20, 2010, 04:19:46 pm »
well, you know about as much about it already as one of us could tell you with the provided description. a picture says a million words.
Reply #2March 21, 2010, 07:25:48 am
Henchman
  • 183
Re: KKK turbo
« Reply #2 on: March 21, 2010, 07:25:48 am »
Reply #3March 21, 2010, 11:34:44 am
Re: KKK turbo
« Reply #3 on: March 21, 2010, 11:34:44 am »
Is there no tag on the turbo?  What about markings/numbers?
Reply #4March 22, 2010, 05:48:20 am
Re: KKK turbo
« Reply #4 on: March 22, 2010, 05:48:20 am »
that looks pretty close to my K24, just that mine has the wastegate sittin 90* from that one.
Reply #5March 22, 2010, 06:46:24 am
dennis
  • 311
Re: KKK turbo
« Reply #5 on: March 22, 2010, 06:46:24 am »
Could be a k24.
http://cgi.ebay.com/ebaymotors/VW-Golf-Turbo-K24-MK1-MK2-1-6td-CY-53249706082-Rabbit_W0QQitemZ380216907075QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item5886b19543
An easy way to tell is the oil return.  If it has a pipe screwed into it before the line, it's k14.  If it has a flanged line held onto the turbo with two bolts it's a K24.
Must be the K14. 15 psi ok to run on this? Think I should be looking for a K24 or T3?
Reply #6March 22, 2010, 11:04:30 am
dennis
  • 311
Re: KKK turbo
« Reply #6 on: March 22, 2010, 11:04:30 am »
15 psi on a k14 is fine.  At 15 psi, by swapping on a K24 or T3 you'll gain absolutely nothing other than more lag.
Yeah, and this one does spool up fast. Next is a small intercooler.
Reply #7March 23, 2010, 03:04:23 pm
dennis
  • 311
Re: KKK turbo
« Reply #7 on: March 23, 2010, 03:04:23 pm »
I was wrong. Its a K24. Is 20 psi too much for stock head bolts?
Reply #8March 23, 2010, 07:23:54 pm
Re: KKK turbo
« Reply #8 on: March 23, 2010, 07:23:54 pm »
i run around 25 psi in a 1.5 n/a. completely stock block, just like it came from the factory. it held up to 30 psi pretty good too, but then i ran somewhere in the high 30's one day, and it split the block.
Reply #9March 24, 2010, 06:16:10 am
dennis
  • 311
Re: KKK turbo
« Reply #9 on: March 24, 2010, 06:16:10 am »
I set it to 20 yesterday. Really cleaned up my exhaust. EGTs seem a bit high. Intercooler toay if I get time. Gotta work on other peoples junk to pay the bills first.
Reply #10March 25, 2010, 08:40:55 am
Mark(The Miser)UK
  • 1557
Re: KKK turbo
« Reply #10 on: March 25, 2010, 08:40:55 am »
Dennis, what does your boost read at 70mph cruising, and say 60, accelerating upto 70 also on the flat?
Cheers,
Mark
Mark-The-Miser-UK
Reply #11March 26, 2010, 05:58:48 am
dennis
  • 311
Re: KKK turbo
« Reply #11 on: March 26, 2010, 05:58:48 am »
70 on the flat I think 3-4 psi at about 750EGT. 60-70 depends on how hard I step on the gas. Maybe up to 15 psi. I will check again tonight though.
« Last Edit: March 26, 2010, 02:19:39 pm by dennis »
