Author Topic: 1.6TD Coolant hoses.  (Read 7669 times)
March 17, 2010, 07:53:11 am
trev
  • 67
« on: March 17, 2010, 07:53:11 am »
Looking for a diagram that shows the hoses and their 'real' names.
At 500,000 KMs, I split a line. PITA.
I'm looking for the line that runs from the water pump up to the flange on the head, with the molded in tap to heat the oil filter.
Either my Google-Fu is out today, or there are not a lot of pictures of the coolant system online. Anyone got a decnt picture?
Any sources besides the dealer in Edmonton?
Kinda rather not put in a mystery used hose, if I on't have to. Not adverse to cutting up a new hose and building a Tee for it, if I have to. Do I have to?
Cheers
  Trev
Reply #1March 17, 2010, 08:15:10 am
rallydiesel
  • 1880
Re: 1.6TD Coolant hoses.
« Reply #1 on: March 17, 2010, 08:15:10 am »
Here's one from germanautoparts. And the connection to the oil filter is to cool the oil, not heat it.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2March 17, 2010, 08:55:37 am
trev
  • 67
« Reply #2 on: March 17, 2010, 08:55:37 am »
Fast! Thanks! ;D
Trying to find a local source, the catalogs have hoses listed but no diagrams. Pictures is good!
Cheers
 Trev
Reply #3March 17, 2010, 09:03:17 am
zagarus
  • 619
« Reply #3 on: March 17, 2010, 09:03:17 am »
now just tell me which hoses you need and ill grab the part numbers for you.
Reply #4March 17, 2010, 10:03:50 am
GEE-BEE
  • 1604
« Reply #4 on: March 17, 2010, 10:03:50 am »
I was going to make the 1.6 coolant hoses in silicone, but tooling was too much,
Best prices and stock was from AUTOHAUSAZ.COM OR GERMANAUTOPARTS.COM
FOR A AAZ 45.00 ( 3 ) ASSYS
Gee-Bee
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #5March 17, 2010, 12:54:27 pm
trev
  • 67
« Reply #5 on: March 17, 2010, 12:54:27 pm »
It's hose number 3 on that diagram. It split right above the molded in offshoot hose.
Thanks! Just printed that one out.
Cheers
 Trev
(Edit) I am figuring it for a Meyle 119 121 0004, aka VW 068 121 053P. Is that correct?
The catalog that the supplier has, showed a hose with that number but ID's it as being for a 1.6TD with Auto Transmission. It looks like a match for the one in the Germanautoparts picture, but the "auto Trans" kinda stumped us. It had the Meyle number visible, I looked that up, it crossed to the VW number.
The VW number looks like it references the 1.6TD correctly. ???
« Last Edit: March 17, 2010, 04:10:23 pm by trev »
Reply #6March 17, 2010, 06:25:43 pm
« Reply #6 on: March 17, 2010, 06:25:43 pm »
Probably a bad description in his book. I don't think VW did a turbo TD?
Reply #7March 17, 2010, 08:07:28 pm
the4ork
  • 331
« Reply #7 on: March 17, 2010, 08:07:28 pm »
in this picture line #18 connects to the aux pump and what? looks like it goes to the reservoir but i dont think it does
Reply #8March 17, 2010, 08:17:44 pm
rallydiesel
  • 1880
« Reply #8 on: March 17, 2010, 08:17:44 pm »
That one goes to the heater core.
