Author Topic: Redneck TDI Intake Cleaning  (Read 5692 times)
February 23, 2010, 03:37:49 am
Syncroincity
  • 727
« on: February 23, 2010, 03:37:49 am »
Redneck TDI Intake Manifold Cleaning!
LOL... there's a few videos there documenting this method.
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
Reply #1February 23, 2010, 08:58:07 am
foxracer1
  • 991
Re: Redneck TDI Intake Cleaning
« Reply #1 on: February 23, 2010, 08:58:07 am »
I did it to a couple intakes works good. Gotta watch the temp of the manifold though.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #2February 23, 2010, 09:59:48 am
« Reply #2 on: February 23, 2010, 09:59:48 am »
someone i know had an old a/c bug, and the heat riser would always get coked up, and the only way we ever got it clean was start heating the heat riser tube FROM THE OUTSIDE to cherry red with an oxy torch, then once you have a spot glowing that has plenty of coke to burn inside the manifold, you cut the gas to the torch and just leave the oxy running. run it THROUGH the heat riser. eventually, the cherry red section of the manifold starts moving towards the other side. and once its done, its clean.
it was kinda cool tho, seeing all the flaming particles of soot flying out of the intake on that video.
Reply #3February 23, 2010, 06:54:19 pm
diesel smoke
  • 209
« Reply #3 on: February 23, 2010, 06:54:19 pm »
*banjo music* I'd totally do it that way. I like fire.  ;D
'99.5 Bora TDI
'88 Fox Coupe
'71 Tin Top Westfalia Bus
'85 Mercedes 300SD
Reply #4February 23, 2010, 09:16:03 pm
commuter boy
  • 277
« Reply #4 on: February 23, 2010, 09:16:03 pm »
Used to decoke two-stroke expansion chambers the same way   8)
