Author Topic: Radio Problems  (Read 4705 times)
November 16, 2005, 03:21:18 pm
3beejay3
Radio Problems
« on: November 16, 2005, 03:21:18 pm »
I have a 97 Jetta TD with the factory Radio/cassetteplayer.
This AM when I left for work The radio was dead; no sound, LCD display was blank.
Anyone familiar with this problem?
I'm going thru the Bentley but it doesn't appear to offer a lot in the way of help in this regard.
Other than checking fuses/ wiring I'm not sure what else to do.
Hate to 'have' to put a new one in'...
BJ
Reply #1November 16, 2005, 03:27:39 pm
tackered
  • 24
Radio Problems
« Reply #1 on: November 16, 2005, 03:27:39 pm »
Check that you're getting accessory power off the ignition switch.
Check that you have a good ground to the radio.
I hate MKIII heat shields.
Quote from: "ultimate steve"
i just hope your a little more careful when the time comes to change your blinker fluid.
Reply #2November 18, 2005, 02:12:51 pm
3beejay3
Radio Problems
« Reply #2 on: November 18, 2005, 02:12:51 pm »
Had power to the radio 'cause the lights for the buttons were still on. Pulled the radio out, the 10a fuse was blown. Put a new fuse in, re-installed the radio. When I was entering the code the fuse blew again.
WTF is going on here???
 This radio hasn't give me any trouble in all the time I've owned the car to this point & I havn't changed or touched any thing on the dash, intruments, controls etc.
Why is there a fuse on the back of the radio?
Anyone have any ideas?
BJ
Reply #3November 18, 2005, 05:17:04 pm
tackered
  • 24
Radio Problems
« Reply #3 on: November 18, 2005, 05:17:04 pm »
You might have an internal short of some sort...
Hey, look on the bright side, you have breakfast... 'cuz your radio is pretty much toast.
