Author Topic: how much smoke is too much?  (Read 7488 times)
February 19, 2010, 05:39:58 am
ashleyroe
« on: February 19, 2010, 05:39:58 am »
on start up in the cold 20 to 30F (or -6 to -1C) with the cold start pulled, i get steady white smoke for about 5-10 mins until the car is warmed up.
question is... is that too much? or there shouldn't be any at all?
i think my cold start needs to be adjusted anyways.
Reply #1February 19, 2010, 08:25:39 am
rallydiesel
  • 1880
Re: how much smoke is too much?
« Reply #1 on: February 19, 2010, 08:25:39 am »
Are your glow plugs good? I get white smoke only while I am cranking. Once it starts, the white smoke is gone except for occasional puffs right at the exhaust pipe. And this is at -15C.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #2February 19, 2010, 08:30:56 am
ashleyroe
« Reply #2 on: February 19, 2010, 08:30:56 am »
yeah they are all brand new from the engine rebuild.
Reply #3February 19, 2010, 08:31:23 am
hippiekiller
  • 73
« Reply #3 on: February 19, 2010, 08:31:23 am »
Check your timing, also your kold start solenoid on the pump (the other wire, not the shut-off solenoid) it advances the timing slightly when the pump is cold...if the smoke dissipates after 5 min of good driving (not idling) I woiuldn't worry...
95 jetta, 2"lift
92 dodge diesel too much to list
Reply #4February 19, 2010, 08:37:18 am
« Reply #4 on: February 19, 2010, 08:37:18 am »
I run my pump at 1.02mm, so with the advanced pulled it sits around 1.05mm.
I also run Bosch Duraterms, with the afterglow feature. I get smoke for the first 5 seconds of running then it is gone. I usually afterglow for 30 seconds.
If it is really bothering you, I would suggest the Duraterms with a manual controller. The afterglow really helps with cold combustion (keeping the precups at 400F, instead of allowing the combustion to heat them up)
Reply #5February 19, 2010, 08:43:27 am
ashleyroe
« Reply #5 on: February 19, 2010, 08:43:27 am »
yeah if i drive it right away it usually stops smoking with in 2-3 mins.
i think my pump is set at .90. i can't remember. i have the tool so maybe i'll screw around with it and see if i can make it alittle better.
Reply #6February 19, 2010, 10:41:46 am
ashleyroe
« Reply #6 on: February 19, 2010, 10:41:46 am »
finshed the rebuild in october.
they were bosch plugs.
no air in any lines.
Reply #7February 19, 2010, 04:52:25 pm
« Reply #7 on: February 19, 2010, 04:52:25 pm »
I watched my tailpipe this morning on first startup at 30F, a nice puff of wonderful black smoke ;D and then it instantly cleared up and only puffed more black when I popped the go pedal. There was no white smoke at all.
Once when I installed the IP I had the belt a tooth off and it smoked white but it also ran horrible. From what I've read most people have good luck with .98mm-1.00mm.
Reply #8February 28, 2010, 12:12:37 pm
ashleyroe
« Reply #8 on: February 28, 2010, 12:12:37 pm »
not sure if it's the case yet until i pull an injector and look, but would upside down heatshields cause this?  ::)
