Author Topic: WTB: oversize pistons for a cy code 1.6 td 030  (Read 8455 times)
February 15, 2010, 12:26:30 pm
NintendoKD
  • 931
    dnahtasinoivilboeraweb
    • myspace page
« on: February 15, 2010, 12:26:30 pm »
You heard it right, I need 030 oversize pistons, having a helluva time finding this oversie size.  If I wanted to bore to 5 over I would, but I much rather go with the size that I have.  The pistons are in rough shape and I don't want to use damaged pistons for my build.  Any info would be greatly appreciated.
Thanks,
Kevin
Reply #1February 15, 2010, 12:29:46 pm
NintendoKD
  • 931
    • myspace page
Re: WTB: oversize pistons for a cy code 1.6 td 030
« Reply #1 on: February 15, 2010, 12:29:46 pm »
This is from an early 1.6 block from an 83' rabbit turbo diesel "RARE" in case anyone was wondering.  Got it from a guy in pollock pines in norcal.  Interesting oversize, if I absolutely must go 5 over I will but I am sure these things are out there. just don't want to pay more that I would if I were to go oversize 5 over machining cost plus the new pistons.  In otherwords I need em' cheap, or I don't need em.  Don't mean to sound the scrooge or anything.
Reply #2February 15, 2010, 02:43:27 pm
ilikevwdiesel
  • 1202
« Reply #2 on: February 15, 2010, 02:43:27 pm »
1.6 pistons are generally sold in .5 and 1.0 mm oversizes, that is .020 and .040
My Bio
Reply #3February 15, 2010, 09:13:03 pm
NintendoKD
  • 931
    • myspace page
« Reply #3 on: February 15, 2010, 09:13:03 pm »
sooooo no in between? mine literally say 030 on top of the piston is that normal?
Reply #4February 15, 2010, 09:16:37 pm
truckinwagen
  • 1895
« Reply #4 on: February 15, 2010, 09:16:37 pm »
they should have the piston diameter stamped on there, like this:
see the "76.72" stamped in the piston?
these are third oversize(I think) there is a chart in the bentley that lists the oversizes and the piston diameters that go with them.
if nothing else you can take a pair of calipers to your pistons and consult the chart in the bentley to figure out which oversize they are.
-Owen
83 Opel Kadett Diesel
Reply #5February 15, 2010, 10:59:38 pm
rabbid79
  • 684
« Reply #5 on: February 15, 2010, 10:59:38 pm »
Those pistons in the picture are probably the "1st" oversize.  It went 76.50-std, 76.75-1st, 77.00-2nd, and 77.50-3rd.  This is in general.  I don't think anybody but VW themselves actually sold true "1st oversize" pistons.  At least, I've never seen an OEM sell them.
As another interesting side note, there are actually different sized pistons within a given "oversize".  The piston in the picture is a perfect example of this.  The second oversize can actually be 76.98 or 77.00mm.  I think it has to do with the manufacturing tolerances.  They group similarly sized pistons with each other, right down to the 1/100mm.  VW even catagorizes them as "blue" or "pink", etc. to indicate which actual size they are of each given oversize.
NintendoKD, I would be a bit surprised if that really is a .030 oversize piston you have there since it doesn't really "fit" the idea of .020 corresponding to 77.00mm and .040 corresponding 77.50mm pistons.  If they really were .030 oversize pistons, they would probably have to be 77.25mm which is a size I've never heard of.  I think the best advice would be measure it and go from there.
'15 WRX
Reply #6February 16, 2010, 06:21:18 am
NintendoKD
  • 931
    • myspace page
« Reply #6 on: February 16, 2010, 06:21:18 am »
Well do, have to wait til wed to see though, stuffs locked up at the shop.  Been wrong before, so this wouldn't be a first ;D
Reply #7February 16, 2010, 09:13:46 am
Dakotakid
  • 1240
« Last Edit: February 16, 2010, 09:15:35 am by Dakotakid »
Reply #8February 16, 2010, 09:43:31 am
« Reply #8 on: February 16, 2010, 09:43:31 am »
Thanks,
Kevin
never seen a set of .030 over pistons ofr a VW before. the size of the piston is usually the diameter, not just the over size amount. it should say 76.48, or 76.98 or something along those lines, on the top of the piston.
Reply #9February 16, 2010, 05:28:53 pm
Dakotakid
  • 1240
« Reply #9 on: February 16, 2010, 05:28:53 pm »
The .030 stamping is expressing the amount of cylinder wall clearance you need: .030 mm
Reply #10February 16, 2010, 05:52:21 pm
NintendoKD
  • 931
    • myspace page
« Reply #10 on: February 16, 2010, 05:52:21 pm »
So I may have stock pistons yet :D *crosses fingers*  I'll be sure to check tomorrow.
Reply #11February 16, 2010, 06:10:53 pm
rabbid79
  • 684
« Reply #11 on: February 16, 2010, 06:10:53 pm »
By the way, I have a set of 5 brand new Kolbenschmidt turbo diesel pistons for sale.  They're "2nd" oversize at 77.00mm (.020).  I know you only need 4 so I'll give you a good deal on just four, or throw in the 5th for not a lot more.  LMK
'15 WRX
Reply #12February 16, 2010, 06:50:56 pm
NintendoKD
  • 931
    • myspace page
« Reply #12 on: February 16, 2010, 06:50:56 pm »
*sighs*  if I have oversize I'll keep you in mind, I need new ones regardless and am really trying to keep from having to machine.  Regardless I'll keep you posted. 8)
Reply #13February 17, 2010, 09:23:00 am
« Reply #13 on: February 17, 2010, 09:23:00 am »
so you are spending all this time and money on this engine, but you cant drop a hundred bucks to get the block bored out to the proper size? it really doesnt make much sense to me. knife edge the crank, dry sump oiling, 1.9 head, but its still got the same bore VW manufactured it with who knows how many miles ago? that does not make good sense to me. and your pistons are already messed up, so you need different ones anyway? so why not just get it bored and call it good?
Reply #14February 17, 2010, 09:18:30 pm
NintendoKD
  • 931
    • myspace page
« Reply #14 on: February 17, 2010, 09:18:30 pm »
If it aint broke don't fix it.  The bores still had cross hatching when I got the block, to me that means that the bores are still good, but that's just me.  I am trying to avoid all of the machining that I can, i'ts a pain to keep taking it back to the machinist and hear his I-told-you-so speech again and again :P ::)  No, but seriously, the bores are fine, why mess up a good thing?  I have to buy pistons regardless why spend the extra 100 bones if I don't have to time will tell, I'll find out tomorrow, completely forgot about it today.  I'll be sure to take some pics too.
