Author Topic: WTB: oversize pistons for a cy code 1.6 td 030  (Read 8399 times)
Reply #15February 18, 2010, 07:40:38 am
Re: WTB: oversize pistons for a cy code 1.6 td 030
« Reply #15 on: February 18, 2010, 07:40:38 am »
If it aint broke don't fix it.  The bores still had cross hatching when I got the block, to me that means that the bores are still good, but that's just me.  I am trying to avoid all of the machining that I can, i'ts a pain to keep taking it back to the machinist and hear his I-told-you-so speech again and again :P ::)  No, but seriously, the bores are fine, why mess up a good thing?  I have to buy pistons regardless why spend the extra 100 bones if I don't have to time will tell, I'll find out tomorrow, completely forgot about it today.  I'll be sure to take some pics too.
cross hatches or not, i pulled my last 1.5 apart (single owner, never been taken apart, EVER) and it had 125k miles on it, and the bores still had cross hatching in them, and only a slight lip. there was still cross hatching in those cylinders too, so im sure your cross hatching is old also. i just wouldnt half ass the pistons/bores. but if you drop your new pistons in, and there at .001" spec, then run it, but if its any looser, i would bore it and go over size. i just dont see why you are gonna skimp on such an important step (in my eyes) and you are willing to splurge on such un-important things such as a complete aftermarket oil system. i think i would rather bore the block, than go with the oil system if it were me, and if i were on a limited budget. i just dont get your method of thinking sometimes is all...
when i built my last engine, no, i did not bore it. but, it has a piston and rod out of a completely different engine. and the bottom of the bore is broken. it still runs great, but i can tell its not right. it has a cold miss that goes away, and uses some oil, more than i would like. by not boring your engine, you are just asking for lots of blow by, and an engine that burns plenty of oil.
i just wouldnt take the chance unless its still at stock VW spec (or atleast super close for piston to cylinder wall clearance.
Reply #16February 18, 2010, 11:56:09 am
NintendoKD
  • 931
    dnahtasinoivilboeraweb
    • myspace page
« Reply #16 on: February 18, 2010, 11:56:09 am »
I'm not on a budget build per-se, just frugal "the mods don't like it when I use a certain ethnic word, even though I am one" ;)  I will spec it out for sure.
Reply #17February 21, 2010, 08:52:36 am
NintendoKD
  • 931
    • myspace page
« Reply #17 on: February 21, 2010, 08:52:36 am »
76.98 thats oversize, and that is what I need 8)
Reply #18February 21, 2010, 11:20:02 am
rabbid79
  • 684
« Reply #18 on: February 21, 2010, 11:20:02 am »
Brand new Kolbenschmidt 76.98 turbo pistons is what I have.  Stamped right across the top of the piston.
'15 WRX
Reply #19February 21, 2010, 05:33:41 pm
« Reply #19 on: February 21, 2010, 05:33:41 pm »
whats your bore mic out at? have you checked yet? how tapered are the bores? how is the ridge at the top of the bore?
Reply #20February 21, 2010, 06:13:11 pm
NintendoKD
  • 931
    • myspace page
« Reply #20 on: February 21, 2010, 06:13:11 pm »
hold on, I have to dig up the ol mic 8)
Reply #21February 22, 2010, 05:57:36 pm
NintendoKD
  • 931
    • myspace page
« Reply #21 on: February 22, 2010, 05:57:36 pm »
Ok, I have a set of calipers, best reading I can get says 76.92, what is the best way to get an accurate reading?  or am I using the wrong tool for the job? ???
Reply #22February 22, 2010, 06:00:09 pm
NintendoKD
  • 931
    • myspace page
« Reply #22 on: February 22, 2010, 06:00:09 pm »
There is absolutely no ridge at the top of the bore, just to be clear.  I gotta be doing something wrong when measuring, it is a digital set of calipers, and yes, I zeroized and calibrated them properly before use.
Reply #23February 22, 2010, 06:07:40 pm
« Reply #23 on: February 22, 2010, 06:07:40 pm »
Are you using bore gauges?
This style lets you use a dial caliper:
http://cgi.ebay.com/ebaymotors/NEW-TELESCOPING-GAUGE-SET-inside-bore-measuring-tools_W0QQitemZ370334514951QQcmdZViewItemQQptZMotors_Automotive_Tools?hash=item5639a83f07
This style has the gauge built-in:
http://cgi.ebay.com/ebaymotors/PRECISION-ENGINE-CYLINDER-HOLE-DIAL-BORE-GAUGE-GAGE-SET_W0QQitemZ370339278224QQcmdZViewItemQQptZMotors_Automotive_Tools?hash=item5639f0ed90
The idea is to take a series of readings in several directions at 3 or more depths on the bore... giving you an accurate picture of mean diameter, taper, etc.
Reply #24February 22, 2010, 06:26:26 pm
NintendoKD
  • 931
    • myspace page
« Reply #24 on: February 22, 2010, 06:26:26 pm »
so in other words, I need to get my machinist to do it for me.... 80 bucks for a guage is not what I was expecting :'(  Thanks Vince, I'll figure something out.  I want to do this myself, but it seems that that may not be the case.
Reply #25February 22, 2010, 06:34:16 pm
« Reply #25 on: February 22, 2010, 06:34:16 pm »
Probably a good idea.  They are an acquired skill to use as well... in terms of repeatability.... for a one-off handing it off to a guy that does this for a living might make sense.
I have a set but I mostly use them to predict how bad the news from the machinist is likely to be.   ::)
Reply #26February 22, 2010, 09:00:36 pm
NintendoKD
  • 931
    • myspace page
« Reply #26 on: February 22, 2010, 09:00:36 pm »
I'll know wed evening :-\  be worried till then :'(
