If you're fine with aftermarket both VDO and Autometer make diesel-compatible tachs.
Quote from: Vincent Waldon on February 12, 2010, 12:49:21 amIf you're fine with aftermarket both VDO and Autometer make diesel-compatible tachs.Now when you say diesel compatible, you mean it will read our W terminal signals and work properly right out of the box? pretty cool. sorry for being a NeWby lol
Quote from: 8v-of-fury on February 12, 2010, 10:25:18 amQuote from: Vincent Waldon on February 12, 2010, 12:49:21 amIf you're fine with aftermarket both VDO and Autometer make diesel-compatible tachs.Now when you say diesel compatible, you mean it will read our W terminal signals and work properly right out of the box? pretty cool. sorry for being a NeWby lolNo worries.... it's all very confusing, and I could have been clearer in my response for sure. The answer to your question is "yes and no"! VDO makes aftermarket tachs that can be driven from the W terminal... part numbers include 333-958, 333-959, 333-164 etc depending on face, RPM range etc. Here's a typical install guide... you hook 'em up to the W terminal, set a couple of dip switches, and the fine-calibrate with a pot adjustment to your specific alt, pulley size, etc:http://www.egauges.com/pdf/vdo/0-515-012-044.pdfI had an older version of one of these on the dash of my 81 pickup... even had a max scale of 5000 RPM so perfect for diesel use. The Autometer versions (p/n 2888 for instance) has a small pickup that straps to any alternator. Stewart Warner evidently makes some that have an alternator pickup as well. Two different styles... either of which allow you to install an aftermarket tach on your diesel.
