Author Topic: Calling Burn you money and others  (Read 5919 times)
February 10, 2010, 09:10:26 am
« on: February 10, 2010, 09:10:26 am »
I thought we had a thread on here about painting our IP.
Tyler was going to paint a guys pump Pink IIRC  ;D
I am wondering whatcould be bad about doing it? I would think less corrosion,rust, whatever on the outside of the pump. Any downsides?
Basically I am looking for things I can do INSIDE for the car while it is so stinking cold and snowy out here.
Reply #1February 10, 2010, 10:09:18 am
GEE-BEE
  • 1604
IP
« Reply #1 on: February 10, 2010, 10:09:18 am »
If you have the time send it out for electroplating, I want to do the same with my injector lines
Giles did such a nice job cleaning my IP, I sent my alt bracket in silver , IP bracket in flat black
I would like to electroplate a transmission in black, and then send it out for a overhaul
G.B.
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #2February 10, 2010, 10:35:32 am
Turbinepowered
  • 1206
Re: Calling Burn you money and others
« Reply #2 on: February 10, 2010, 10:35:32 am »
I plan on getting an IP blacked, with the hydraulic head and the high pressure lines copper-plated then clear-coated. Copper-plate the injectors, black head, black block. Black alternator, copper water pump and housing. Copper timing sprockets, black belt pulleys.
All black vacuum lines and water hoses, "copper" water hardpipes. Copper brackets and black rigid tube for all the wiring, and black soft-wrap for wires once they leave the tubes.
:D
Reply #3February 10, 2010, 11:09:48 am
GEE-BEE
  • 1604
« Reply #3 on: February 10, 2010, 11:09:48 am »
I did the polyethlene tubing for my wires with the samco silicone tape for the ends
Boostcontroller.com sells the samco tape( black )
the tubing from ebay, cheap
Finally found the five clip part #'s for the aaz coolant hardline
waiting on them with my vw dealer
Giles Pump OHC
MK1 JETTA DASH
Reply #4February 10, 2010, 03:52:56 pm
« Reply #4 on: February 10, 2010, 03:52:56 pm »
Phew, thought I was getting called out for something I forgot to do
http://www.vwdiesel.net/forum/index.php?topic=22545.0
Reply #5February 10, 2010, 04:43:04 pm
Turbinepowered
  • 1206
« Reply #5 on: February 10, 2010, 04:43:04 pm »
And my last comment in that thread still stands. :p
Reply #6February 10, 2010, 04:47:19 pm
« Reply #6 on: February 10, 2010, 04:47:19 pm »
OK, so what do you mask off besides input, output, fuel selinoid, and boost line? I am thinking a nice gloss black.
And I wouldn't call you out on not sending peices...it takes time to get from canada to ohio  ;)
« Last Edit: February 10, 2010, 04:49:24 pm by theman53 »
Reply #7February 10, 2010, 05:48:55 pm
« Reply #7 on: February 10, 2010, 05:48:55 pm »
The 4 high pressure outlets, the vent for the LDA. I think I had the throttle lever and springs removed but that's a bit overkill
Reply #8February 10, 2010, 08:26:16 pm
« Reply #8 on: February 10, 2010, 08:26:16 pm »
Gloss black? Army Tank Green w/White Star ;) (I think we had this exact same discussion, the other way around about a year ago Lucas lol)
Reply #9February 11, 2010, 06:44:07 am
stewardc
« Reply #9 on: February 11, 2010, 06:44:07 am »
Yerah, I did my Giles pump in semi-gloss black. It looks mean.
