suspension upgrade questions
by
on 06 Feb, 2010 09:21
I am completely new to upgrading suspension. So I need to know what works and what doesn't. My goal is for it to last, handle better, and still give a good ride. I live in the country and the roads aren't the greatest, so lowering isn't an option...unless someone has a full bottom skid plate that attaches to an 86 Jetta for free. I definately am going to go with strut tower brace, but don't know who would make them or what is best out there.
I would love to hear from people that know or have done this to there cars as to what is best. Thanks Lucas ><>
#1
by
on 06 Feb, 2010 19:31
my gf's 90 has all brand new KYB gas struts with reused strut mounts.. Some rough roads up here from all the non maintanenced roads.. and heaving from winter freezing. Rides very well.
What kinda suspension you lookin in to Lucas?
#2
by
rallydiesel
on 06 Feb, 2010 20:28
Another very good one is Bilstein PSS9's. They're pricey though. But you get adjustable compression and rebound dampening and it's a very durable coilover.
#3
by
on 07 Feb, 2010 15:01
I can get along in anything, but I would like something that will take abuse of these bad roads here. I am not awfully concerned about ride quality, as long as it lasts forever. I would like a nice ride, but I will sacrifice comfort for longevity is what I am saying.
Basically I am looking for a long lasting, cost effective, great handling solution for when I do the alignment on my project car in my build thread. I have had enough vw's to know that if you do one wheel bearing in 6 months you will do the next one, then a strut, then a ball joint...I want to do it all at once and have it stick to the road and last once it is done.
My friend that drag races a 1.8 gasser says that I have to put strut tower braces in as the handling difference is night and day. I have road in his cars and like what it did for him so I am going that route. I just don't know where to source or what to get when it comes to suspension parts.
#4
by
akrallysport
on 11 Feb, 2010 02:15
In most cases, a simple shock upgrade is sufficient with stock springs as long as they aren't sagging. A good option might be the Bilstein HD struts/shocks and would be complemented by H&R OE Sport type springs (0.5" lowering), although not necessary. Installing the solid rubber lower control arm bushings from a TT/R32 will help eliminate some of the mush in front, while OEM trailing arm bushings are still the ideal to maintain compliance. And don't buy cheapo ball joints and tie-rod ends... I've changed at least 5 or 6 in the past 3 years due to our potholes and late night drives on dirt roads on the way to the cottage.
#5
by
on 11 Feb, 2010 08:49
akrallysport
That sounds perfect. I have no clue where to get it. I can find bilsteins, but the rest...could you help a guy out with some places to check?
#6
by
akrallysport
on 11 Feb, 2010 10:41
#7
by
FineFrank
on 11 Feb, 2010 21:39
Hard to go wrong with Bilstein, or KYB if you're on a budget. Nearly any strut will make your car work better, so long as you dont go cheap, like Sachs et al. I bought Sachs OEM's and had to change them out in less that 10K.
I'd reccommend Bilstein HD's all around, and a good sway bar front and rear. Don't forget to change out the front strut bearings and ball joints, and the wishbone bushings with quality stuff.
If you're definately going to install a strut tower brace, do it AFTER you install a lower brace for the frame horns- it's more important, if less visible. VW put them on the Scirocco, it's called a Kbar.
Godspeed, friend.
#8
by
on 18 Feb, 2010 21:27
I talked to my friend about the Lower strut bar brace and he said that is only more important for MKI cars. The MkII with its subframe it isn't as needed as the top according to him. He did say it is completely opposite for MKI...was that what you were refering to?
#9
by
GEE-BEE
on 19 Feb, 2010 12:21
WEITEC COILOVERS
RABBITPARTS.COM
#10
by
FineFrank
on 19 Feb, 2010 13:30
Yes. Failed to read your OP thoroughly, and yor friend is right, I'm wrong.
#11
by
on 24 Feb, 2010 21:40
WEITEC COILOVERS
RABBITPARTS.COM
I couldn't find any for MKII or that were stock ride height.
#12
by
smokin_fun
on 25 Feb, 2010 03:18
I highly recommend H&R street coil overs. You can go for 1 inch below stock (euro stock that is) to like 5 above. I am about 1.5 above stock and i LOVE it. Forget lowering cars, I actually like the country, and the roads are always better there. It handles AWESOME, it rides awesome, and yes definitely get a strut bar. I have an autotech??? maybe but i had heard before i bought it to get an adjustable one. They really make a difference!
As far as i have seen all coil overs will go above stock height, add in the diesel sound and it feels like yer in a ford f250. Yeeehaw
Actually alot of the rally guys run Hot Bits coil overs and really like them. If they hold up to rallying they must be good.
www.hotbits.cawww.hrsprings.com
#13
by
on 26 Feb, 2010 18:32
WOW
There is a lot of pricey stuff out there. I think I would like a setup like the coilover, but whose to choose. I can see spending 1,000.00 or so, but more than that I don't think is realistic. I don't need more than that I don't think. I also would spend it only if I can take it with me to everyother vehicle I ever own. some of those linked are almost 2 grand
There has to be a really good setup for around a grand.
#14
by
on 27 Feb, 2010 09:36
On the rear swaybar, how many in/lbs is desired? Once again MKII jetta and I am looking for life of components first, performance and ride would be second. I also can hual weighted stuff sometimes and don't know how that effects things. Also, when it comes to Koni vs bilsteins is there much difference in life, ride, and performance?
