Author Topic: F/S complete engine and transmission for a three owner 80' rabbit diesel  (Read 1457 times)
February 02, 2010, 01:59:18 pm
NintendoKD
  • 931
    dnahtasinoivilboeraweb
    • myspace page
I want to sell it as a set, but will part out, the injection pump and injectors leak superficially only so they probably need a new rebuild.  The engine has 150ish' k miles on it and ran great very clean cyl. head will resureface before I send it out.  I do good work, don't believe me, just check out my thread:
http://www.vwdiesel.net/forum/index.php?topic=22148.0
I had problems with it shortly after buying it, come to ind out that everything is fine, just air in the fuel lines "they are OEM original from the factory"  Needs new rubber, clear fuel lines run and the pump and injecotrs will need a rebuild.  You can buy a new H/G and head bolts and make her run with a working I/P.  Once again, the engine is sound, and runs great, I misdiagnosed and pulled the head only to find out that everything is fine.  Make me a reasonable offer on this, local pickup is preferred, but I can freight it at the buyers cost.  call me 6618162150 Kevin.  I have the complete exhaust, and everything cleaned and ready for powdercoat as well, will post pics shortly, new glow plugs are already in the head.  Anything else needed just call.  I have totaled my car and need cash, don't lowball me, but any reasonable offer will be great ANY REASONABLE OFFER!!! ;D
thanks,
Kevin
Reply #1February 02, 2010, 02:02:10 pm
NintendoKD
  • 931
    • myspace page
Re: F/S complete engine and transmission for a three owner 80' rabbit diesel
« Reply #1 on: February 02, 2010, 02:02:10 pm »
Sorry, Don't know how, but this ended up in the completely wrong section.  MOD, delete please?  I reposted in the for sale section.
thanks,
Kevin
