Author Topic: My first motor swap.  (Read 4567 times)
January 29, 2010, 09:51:42 pm
superbro
  • 45
« on: January 29, 2010, 09:51:42 pm »
Hey guys I'm geting ready to do my first motor swap. Can you guys give me any ponters? I have helped with a fue so I kinda know what I'm doing but not realy. So any thing helps.
Thanks
2005 TDI Jetta Wagon 5 speed.
 Sold :'( 1983 Caddy 1.6 N/A 5 speed. Daily driver.
Reply #1January 29, 2010, 10:30:53 pm
lovinthedeez
  • 489
Re: My first motor swap.
« Reply #1 on: January 29, 2010, 10:30:53 pm »
soooooooo........i think we need more info here. ::)
stuff like
the car?
the motor?
oh yeah, we like pics :P
Reply #2January 29, 2010, 10:56:27 pm
mystery3
  • 774
« Reply #2 on: January 29, 2010, 10:56:27 pm »
Mark EVERYTHING, keep a log with some short descriptions and sequence of what you're doing, read bently.
Reply #3January 30, 2010, 05:18:45 am
« Reply #3 on: January 30, 2010, 05:18:45 am »
Get a good sized cardboard box and flatten it. Draw squares on it and label each square with the location of the nuts and bolts you take out. Put the nuts and bolts in said squares.
Reply #4January 30, 2010, 08:35:59 am
« Reply #4 on: January 30, 2010, 08:35:59 am »
lol, i like how we pretty much tear him apart before he even gets a second response.
we are such a loving bunch  8)
Reply #5January 30, 2010, 08:59:26 am
superbro
  • 45
« Reply #5 on: January 30, 2010, 08:59:26 am »
Sorry about that. 83 caddy, 1.5n/a 4 speed coming out. Putting in 1.6 n/a with a 5 speed. The 1.6 has been re built.
Reply #6January 30, 2010, 09:09:22 am
« Reply #6 on: January 30, 2010, 09:09:22 am »
the hardest part is going to be the shifter linkage.
Reply #7January 30, 2010, 09:19:13 am
« Reply #7 on: January 30, 2010, 09:19:13 am »
Good call, do you have all the 5 speed shifter pieces?
Do you have an engine hoist? I would drop the engine and lift the truck up over it.
Does the 5 speed have the driverside mount on it already? It is different then the 4 speed one.
Loosen off the axle nuts (30mm) before you jack the truck up. Do not roll the truck around without the outer axles installed or you will destroy your wheel bearings.
Reply #8January 30, 2010, 10:02:59 am
superbro
  • 45
« Reply #8 on: January 30, 2010, 10:02:59 am »
Yes I have the 5 speed links. Y would you lift the truck and not just lift the motor and trany? I beleve I have all the mount brackets.
Reply #9January 30, 2010, 10:12:08 am
lovinthedeez
  • 489
« Reply #9 on: January 30, 2010, 10:12:08 am »
the bentley says which pieces are different are different for the linkage;  iirc the selector bracket on the transmission itself, and one of the connecting arm thingeys are the only difference.
and as for lifting the truck.  I tried just for shiggles to put one in through the top recently(I always go from below.  you can pretty much have the motor completely put together and just bolt it into the car.  it won't work like that from the top.  weird angles to deal with versus straight up.
Reply #10January 30, 2010, 10:28:49 am
« Reply #10 on: January 30, 2010, 10:28:49 am »
says who? how would that destroy anything? the axle is fastened to the hub, not the wheel bearings. the wheel bearings still have load on them anyway. how does the axle not being there have any affect on it? i just dont see how this can even be possible? cause ive rolled plenty of VWs around with no axles, and even for some longer distances, and the bearings faired just fine.
and superbro, if you try and take the engine out through the hood, you will know why we told you to go out through the bottom. just take our words on it here. or you can try doing it yourself. either way, the engine will be going back in through the bottom if you are smart.
and if you dont have the 5 speed specific mount, you are SOL. 4 speed ones are different enough its hard to modify them to even work.
and make sure the 5 speed going in has the same 90mm drive flanges. if it doesnt, you will need to swap flanges or build some axles. ive done both ways, and neither is hard to do. my rabbit has mk1 axles with mk2 100mm inner cv joints. my gti had the flanges swapped.
also, you need every thing basically besides the shift shaft from the shifter. there are more than one or 2 specific pieces. ive done a few 5 speed conversions, and never used the same combination of pieces twice. my rabbit was half 4 speed links and half 5 speed links, with a 5 speed shifter relay (the piece that bolts onto the splined shift shaft) and relay rod, going to a 4 speed relay ball, with a 4 speed rod from that. and the gear selector shaft was straight forward.
Reply #11January 30, 2010, 10:47:57 am
« Reply #11 on: January 30, 2010, 10:47:57 am »
I was under the impression that any bearing that has a split inner race like our vw's and have a specific axle nut torque are the bearings that need preload. Solid inner race bearings like a GM product the bearing is preloaded when they are made so they would be different. Maybe after the bearing has been compressed and there is no engine in it you might have some luck moving it around, but I wouldn't think you would want to tow it for 1,000 miles or anything.
Reply #12January 30, 2010, 10:54:26 am
« Reply #12 on: January 30, 2010, 10:54:26 am »
Yup.... from the MK2 Bentley, Chapter 11 page 14 under "Suspension and Steering":
"Caution:  Moving a car with the axles removed will quickly damage the wheel bearings.  If moving the car is necessary, always secure the bearing races by temporarily installing an old outer CV joint in the hub, or hold the bearing races in place with two large washers and a suitable bolt and nut"
As theman53 says, the front wheel bearings are a split design and rely on the axle to hold them together.  I keep an old set of outer CV joints on hand just for this purpose... much easier on the peace-of-mind. ;)
« Last Edit: January 30, 2010, 10:57:23 am by Vincent Waldon »
Reply #13January 30, 2010, 11:28:08 am
superbro
  • 45
« Reply #13 on: January 30, 2010, 11:28:08 am »
Cool guys. How would I lift the truck over the motor? I have all the cv suff worked out. I will hafto look and see if I have the right mounts. I also have two 5 speed links and all the 4. So would I just mix and match till it works?
By the way the names Aaron
Reply #14January 30, 2010, 11:30:34 am
« Reply #14 on: January 30, 2010, 11:30:34 am »
most of the problem is getting the shifter to go over far enough to actually engage fifth gear. you need some 5 speed specific parts for sure, no other way around it. i would start with a whole 5 speed linkage setup first, and go from there.
