Author Topic: can I run a turbo pump on a n/a  (Read 2983 times)
January 29, 2010, 08:21:08 pm
lovinthedeez
  • 489
« on: January 29, 2010, 08:21:08 pm »
so I just got a nice deal on a used bosch turbo pump.  I really only want to make SURE that it works before I can't get my monies back.  can I run this and just not have the lda hooked up? don't plan on running the pump on my n/a, just kinda planning for the future I guess. :P
Reply #1January 29, 2010, 11:43:11 pm
Re: can I run a turbo pump on a n/a
« Reply #1 on: January 29, 2010, 11:43:11 pm »
YES ;D
Reply #2January 30, 2010, 08:44:38 am
« Reply #2 on: January 30, 2010, 08:44:38 am »
you just gotta have 155 bar infectors for the pump to time to spec. but whatever engine it bolts to, it will work. 1.5, 1.6, and 1.9
Reply #3January 30, 2010, 10:08:12 am
lovinthedeez
  • 489
« Reply #3 on: January 30, 2010, 10:08:12 am »
The timing spec should match whatever injectors you use regardless of which 1.6 pump is used.  In other words if you use 130 bar injectors, time to the n/a spec.  If you use 155 bar injectors, time to the TD spec.  Whether it's a 1.6 n/a pump or a 1.6TD pump doesn't affect that.  I'd stick with the 130 bar injectors and time it to the n/a spec.
good info there.  good to hear that I won't have to get 155's (just yet ;D) just to see if this thing is the biz or not.  thanks guys.
Reply #4January 30, 2010, 10:29:29 am
« Reply #4 on: January 30, 2010, 10:29:29 am »
one thing to remember, the higher the break pressure, the better the fuel will be atomized. and it should yield better mpg.
Reply #5January 30, 2010, 10:43:45 am
lovinthedeez
  • 489
« Reply #5 on: January 30, 2010, 10:43:45 am »
yup.  the car most likely won't move.  I just want to bolt it on there, and get an idea of the condition of the pump, which was advertised to me as a unit that was removed from a running td that the owner stripped one of the head bolt holes in the block, and scrapped it.
hey rabbit on roids.  you got any extra pump sprockets kickin around? ;D
Reply #6January 30, 2010, 11:28:23 am
« Reply #6 on: January 30, 2010, 11:28:23 am »
hell yea i do. quite a few.
