Author Topic: is it possible to replace the main bearings in a mk1 without removing the motor?  (Read 5125 times)
January 26, 2010, 04:04:05 pm
ilikevwdiesel
  • 1202
anyone ever done it? transmission and clutch must make it impossible huh?  :D
My Bio
Reply #1January 26, 2010, 04:06:54 pm
truckinwagen
  • 1895
it can be done with the crank in, but you need something that can push the upper bearing shell out without damaging the crank journals.
I have done mains in the car by removing the trans and dropping the crank, not an easy job by any means.
83 Opel Kadett Diesel
Reply #2January 26, 2010, 04:20:16 pm
Yuppers.
My favorite tool for this is a plastic putty knife cut to the same width as the bearing... push on the end of the bearing without the tang and they literally  swing around into your hand.  Some folks use an old bearing shell.... the idea is something soft... although truth be told the crank journals are actually pretty darn tough.
I also use a screwdriver that has the blade flattened on a grinder as a press to ensure the new bearing shell is exactly flush after it as been spun on.
« Last Edit: January 26, 2010, 04:23:33 pm by Vincent Waldon »
Reply #3January 26, 2010, 06:43:53 pm
  • 2930
I've used a flattened piece of copper to push them around.
 Last post I saw with a guy doing this;
 he couldn't get number one out,..
 until he loosened the timing belt.
Reply #4January 26, 2010, 07:32:42 pm
janb
  • 167
Yuppers.
I would do the rod bearings, but forget the mains, unless it has well over 300K miles / 500K km.  I have little indication of mains wearing on really old engines.
The Stealth Rabbit
VW-d's are forever
Reply #5January 27, 2010, 08:25:29 am
I agree, my machine shop guy said that he's never seen a watercooled VW engine need mains that didn't otherwise have any damage.  Though the thrust washer/bearing will normally go way before the mains do, especially if it is not installed properly or crank endplay is off, or if people like to sit at red lights with the clutch held in.  :P
Reply #6January 27, 2010, 09:05:42 am
arb
I especially like the guys who slip the clutch on a hill to hold it there at a light.
