Author Topic: semi-noob ?, cold start idle adjust  (Read 4272 times)
January 19, 2010, 05:22:10 am
Vanagoner
  • 219
« on: January 19, 2010, 05:22:10 am »
I have never tried to adjust the fast idle on my cold start lever.  At present it doesn't kick the idle up at all when it is pulled.  What do I do to make it idle faster when it is pulled out?
Also, do I need to loosen the injector lines at the pump when changing the timing?
Thanks
Sage
Reply #1January 19, 2010, 07:37:39 am
Vanagoner
  • 219
Re: semi-noob ?, cold start idle adjust
« Reply #1 on: January 19, 2010, 07:37:39 am »
Thanks Andrew, I'll make sure to loosen them all even for small adjustments.
No, the stock vanagon pump is on a shelf.  I have a mk II (I think) pump out of an '86 jetta, with the pushrod and spring thingy on the side.  Just don't know how to adjust it.
Sage
Reply #2January 19, 2010, 09:56:41 am
« Reply #2 on: January 19, 2010, 09:56:41 am »
On the top of the pump near the rod there are 2 10mm nuts locking studs into the housing. Have a look at both of them and see which way the lever is trying to move when you pull the cold start out. It will be hitting one of those studs. Back it off until you have the fast idle where you want it.
Reply #3January 19, 2010, 09:59:16 am
« Reply #3 on: January 19, 2010, 09:59:16 am »
Or if you can post a picture of the back of the pump ('cause there's lots of different variations) we can photoshop it for you... but Tyler's description will probably do the trick as well.
Reply #4January 19, 2010, 08:30:22 pm
Vanagoner
  • 219
« Reply #4 on: January 19, 2010, 08:30:22 pm »
I'm still kind of picture challenged regarding the innernets, but thanks for the offer Vincent.
Thanks Tyler for the description, I understand that and should be able to make it work for me.
Sage
Reply #5January 19, 2010, 08:32:08 pm
« Reply #5 on: January 19, 2010, 08:32:08 pm »
I hope it helps. There is a FAQ on posting pictures in the FAQ section.
