Author Topic: pump swap. aaz pump on 1.6??  (Read 2449 times)
January 17, 2010, 11:54:49 am
D1ES3L
  • 62
« on: January 17, 2010, 11:54:49 am »
wondering if anyone may know if a 1.9AAZ injection pump will work on an 1.6td? I believe the injectors are single stage but I'm not quite sure how to tell. are they just taller?
My goal is to just get the motor in my caddy running for now as all my pumps seem to be junk.
also thinking about getting my 1.6td pump rebuilt by giles and then running it on the 1.6 until I install my aaz motor. Would this pump work well with the aaz motor or is the aaz pump quite different?
thanks for anyones insight.
« Last Edit: January 17, 2010, 08:14:12 pm by D1ES3L »
81 scirocco--80 TD caddy--99.5 TDI golf
Reply #1January 19, 2010, 10:48:16 am
D1ES3L
  • 62
Re: pump swap. aaz pump on 1.6??
« Reply #1 on: January 19, 2010, 10:48:16 am »
help
Reply #2January 19, 2010, 11:03:37 am
« Reply #2 on: January 19, 2010, 11:03:37 am »
either pump will work on either engine with the correct sprocket.
i would keep the injectors matched to the pump tho. like if your using the AAZ pump, use the AAZ injectors. but it may not even be that important. ive heard of guys running things as mis matched as you could get and it still ran fine.
