Author Topic: Auto-Tragic Gearing  (Read 5762 times)
January 14, 2010, 07:36:44 pm
Auto-Tragic Gearing
« on: January 14, 2010, 07:36:44 pm »
Are there different gears in the auto boxes that came in mk2's? Between gas and diesels?
I was just wondering, as I want to get a diesel engine in my gf's car. Currently she has a '90 1.8 8v digi 3spd auto w/200k. It will cruise at 100km/h at 3000rpm little high for a diesel I know.. Thats why i was wondering if there is a difference between the gearing of gas and diesel auto's
What are you guys thoughts. She doesn't want to do stick.. and i would say just get a diff car.. but this one is mint interior.. so i don't really want to get rid of it..
Whats the verdict  ;)
Reply #1January 14, 2010, 08:18:51 pm
maxfax
  • 2126
Re: Auto-Tragic Gearing
« Reply #1 on: January 14, 2010, 08:18:51 pm »
Get a new GF that'll shift gears???   ;D
OR
Check this out http://www.techtonicstuning.com/trannyratios.asp
Looks like the final drive is the only thing that is different between any of the 010's..  I believe I've heard others say the same in the past..
Reply #2January 14, 2010, 08:29:18 pm
Dakotakid
  • 1240
« Reply #2 on: January 14, 2010, 08:29:18 pm »
The diesel automatic starter is a pretty rare item to find. Unless you have access to one already.
Reply #3January 14, 2010, 08:36:34 pm
maxfax
  • 2126
« Reply #3 on: January 14, 2010, 08:36:34 pm »
IIRC the armature and fields are different in such that swapping the gasser nose on to the diesel starter is out of the question..  Reman starters for the auto trans are pretty available though..  Find a dumb parts guy that'll take the gasser one as a core..
Reply #4January 15, 2010, 09:52:50 am
« Reply #4 on: January 15, 2010, 09:52:50 am »
OR
i second this option... if she cant move her foot and work a stick at the same time, what good is she?
chicks that can drive sticks are usually better skilled in bed..
Reply #5January 15, 2010, 09:59:10 am
« Reply #5 on: January 15, 2010, 09:59:10 am »
Use a passat auto with the 4 speed.
I'm pretty sure there are different ratios. I don't have my bentley with me right now though
Reply #6January 15, 2010, 03:18:56 pm
« Reply #6 on: January 15, 2010, 03:18:56 pm »
I'm not even touching this one :P
Is the 4spd you speak of the 096 or the 01M trans?
Will it bolt up to a 1.6? and mk2 axles? or is there some modding needed to be done?
Reply #7January 15, 2010, 03:30:38 pm
« Reply #7 on: January 15, 2010, 03:30:38 pm »
I don't know. It is electronic so you will need the ECU and throttle body (TPS). I would assume 096 but we know how that goes...
