Author Topic: KO3 Hybrid Turbo ( KO4 Housing Exhaust Side )  (Read 3944 times)
January 11, 2010, 07:32:33 am
GEE-BEE
  • 1604
« on: January 11, 2010, 07:32:33 am »
It finally arrived !
KO4 exhaust Housing with KO3 Inlet Housing
I had both Housings ceramic coated for long life and lower temp
Shaft and impellers balanced
Standard Overhaul KO3 395.00
Plus Ceramic Coated Housings
KO4 Upgrade
Thanx to Jerry at  GPOPSHOP.com
Email me at: [email protected]
« Last Edit: January 15, 2010, 11:45:15 am by GEE-BEE »
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #1January 11, 2010, 09:09:22 am
blackdogvan
  • 574
Re: KO3 Hybrid Turbo ( KO4 Housing Exhaust Side )
« Reply #1 on: January 11, 2010, 09:09:22 am »
Pictures please. When are you installing it?
1991 Vanagon 1.9 mTDI
Reply #2January 11, 2010, 01:33:50 pm
gnavs
  • 340
« Reply #2 on: January 11, 2010, 01:33:50 pm »
Allow me gee-bee.  These are the pics he sent me, good looking piece of machinery  ;D
Reply #3January 11, 2010, 04:18:42 pm
GEE-BEE
  • 1604
« Reply #3 on: January 11, 2010, 04:18:42 pm »
I have two pump's going to Giles ( one for me ) & core and a new set of Injectors for him to adjust.
I will wait on a new Oil return line and for the price I will to have a new S/S oil supply made also.
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #4January 14, 2010, 08:56:04 am
blackdogvan
  • 574
« Reply #4 on: January 14, 2010, 08:56:04 am »
Any chance those pictures got lost in cyberspace?? Looks like gnavs tried but...
Reply #5January 14, 2010, 10:29:06 am
gnavs
  • 340
« Reply #5 on: January 14, 2010, 10:29:06 am »
Am i the only one who can see the pics?  They're linked from my hotmail, haven't had issues doing that in the past...
Reply #6January 14, 2010, 10:31:41 am
truckinwagen
  • 1895
« Reply #6 on: January 14, 2010, 10:31:41 am »
nope, cant see them.
try hosting them on photobucket or the like
83 Opel Kadett Diesel
Reply #7January 14, 2010, 10:51:55 am
blackdogvan
  • 574
« Reply #7 on: January 14, 2010, 10:51:55 am »
Yes you are seeing things...
Reply #8January 14, 2010, 12:31:02 pm
gnavs
  • 340
« Reply #8 on: January 14, 2010, 12:31:02 pm »
weird, I'll upload to photobucket later when I'm at home.
Reply #9January 15, 2010, 11:23:34 am
gnavs
  • 340
« Reply #9 on: January 15, 2010, 11:23:34 am »
take 2..........
Reply #10January 15, 2010, 03:12:21 pm
blackdogvan
  • 574
« Reply #10 on: January 15, 2010, 03:12:21 pm »
So whats the goal for this turbo? All the K03 hybrids i've seen are the opposite to this, a k03 turbine & k04 compressor. A bit more lag but a more efficient top end here?
Reply #11January 15, 2010, 05:16:17 pm
GEE-BEE
  • 1604
« Reply #11 on: January 15, 2010, 05:16:17 pm »
KO4 on the hot side , turbo works easier and will hold up longer
My KO3 was not in good shape, I sent in several cores that I had no use for KO3 & K14
I was happy with what I received from GPOPSHOP...
For me the ceramic coating on the housings was just a option and will complete my engine compartment
2.5 S/S down pipe and complete exhaust , new injectors and Lines with a Giles pump next week
I should have the Silicone AAZ engine hoses finished in about 5 weeks
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #12January 16, 2010, 07:48:58 am
« Reply #12 on: January 16, 2010, 07:48:58 am »
well, what do you think happens to all those K03 cold sides and K04 hot sides? they gotta do something with all the unwanted parts. haha.
Reply #13January 16, 2010, 12:52:11 pm
GEE-BEE
  • 1604
« Reply #13 on: January 16, 2010, 12:52:11 pm »
This is all new part's , balanced shaft also with impellers.
I added new supply line , new return line ( drain ) and all new hardware
Sending the Pump bracket out with the alt brackets for powder coating.
Waiting on new silicone hoses assys ( one piece design )versus those crappy three piece with a plastic tee that are known to leak.
GB
Giles Pump OHC
MK1 JETTA DASH
