Author Topic: K24 oil drain flange size?  (Read 4286 times)
January 10, 2010, 03:23:44 am
TrentB
  • 9
« on: January 10, 2010, 03:23:44 am »
So I'm trying to track down a oil drain for my K24 and realize the OEM ones are pretty much NLA and used ones tend to leak, and I saw the ones that prothe has but, i'll be dammed if i'll deal with that crook. So my last option is to just build one but, I'm having troubles locating the flange part that connects to the turbo. All the ones I'm finding are for K26, K14, T3...etc.  Silly question but would one of those be the same size?
I looked through this thread but nobody said anything about the flanges.  http://www.vwdiesel.net/forum/index.php?topic=19623.0
Thanks for any help.  :)
Reply #1January 10, 2010, 05:37:27 am
Reply #2January 10, 2010, 08:47:08 am
GEE-BEE
  • 1604
Re: K24 oil drain flange size?
« Reply #2 on: January 10, 2010, 08:47:08 am »
WHAt are you going to do on the block return ?
hose size-8
an-8 fittings
Teflon hose is best for temp rating
DISCOUNTHYDRAULICHOSE.COM
Has this fitting that is 90 degree -8 flared to a metric - 18 for your block
part #9069-08-18 9.17
GB
« Last Edit: January 11, 2010, 07:12:22 am by GEE-BEE »
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #3January 10, 2010, 11:49:05 am
TrentB
  • 9
« Reply #3 on: January 10, 2010, 11:49:05 am »
Thanks for the replies but like I said.
Reply #4January 10, 2010, 11:59:17 am
GEE-BEE
  • 1604
« Reply #4 on: January 10, 2010, 11:59:17 am »
Some turbo models have a hard line tube that connects to a female fitting, others T3 larger adapter and Ko3/ko4 have a smaller adapter ( two bolt to a banjo fitting )
I have a new KO4/KO3 hybrid, same as KO3 and i did a adapter flare ( ebay ) to a teflon Aircraft hose assy to a Tomkin adapter as noted above.
There are two different sizes of adapters for the return line( turbo mount )
send me a pic
[email protected]
Hope this help's
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #5January 10, 2010, 12:02:39 pm
Reply #6January 10, 2010, 12:10:22 pm
TrentB
  • 9
« Reply #6 on: January 10, 2010, 12:10:22 pm »
This is the style I am looking for. (from prothe's website non the less)
I measured the area on the turbo where the flange meets and the flange has it's bolt centers 50mm apart.  I found one on ebay that gave measurements of 37.5.  Which is why I'm asking if someone has already knows if one from another KKK turbo or other would work.
Reply #7January 10, 2010, 12:11:53 pm
Reply #8January 10, 2010, 02:03:32 pm
GEE-BEE
  • 1604
« Reply #8 on: January 10, 2010, 02:03:32 pm »
Yes that is the larger adapter than the KO3 style turbo adapter, I would go with that adapter listed above ( it will work )and make up a dash -8 AN Spec  hose assy and change the fitting on the block..
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #9January 10, 2010, 04:20:55 pm
rallydiesel
  • 1880
« Reply #9 on: January 10, 2010, 04:20:55 pm »
I had a custom flange made for both ends. Converted to a common AN fitting. I would recommend doing this and ending the leaking and weird size problems once and for all.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #10January 10, 2010, 04:50:16 pm
« Reply #10 on: January 10, 2010, 04:50:16 pm »
the stock T3 vw drain line fits on a K24. same flange.
Reply #11January 10, 2010, 04:58:52 pm
TrentB
  • 9
« Reply #11 on: January 10, 2010, 04:58:52 pm »
The golden question is now. Is that flange the same as all other non-vw T3's?  I'm going assume yes. But I would still to hear someone buying a aftermarket flange and putting it on a K24.
Guess I'll dig around one the internet more and see if i can find flange sizes.
Reply #12January 11, 2010, 09:03:59 am
« Reply #12 on: January 11, 2010, 09:03:59 am »
no idea if vw and standard flanges are different or not. i know my return line bolts up to a volvo K26 also.
