Author Topic: GP relay temperature sender  (Read 2211 times)
December 29, 2009, 04:45:20 pm
ToddA1
  • 434
« on: December 29, 2009, 04:45:20 pm »
My GP relay won't engage when hooked to either, but the gauge in the car works when hooked to either.  When I leave the blue/white to the sender disengaged, the relay works properly.
Both AutohausAZ and GAP list both senders as being the same.  What gives?  Anyone have a part #?
For now I'll just leave it unplugged, but I do want it fixed for the warmer weather.
-Todd
***edit***
Actually, if I leave the blue/white disconnected, will the relay & GPs keep energizing when the engine is at operating temperature?
« Last Edit: December 29, 2009, 04:50:41 pm by ToddA1 »
Reply #1December 29, 2009, 05:15:02 pm
Re: GP relay temperature sender
« Reply #1 on: December 29, 2009, 05:15:02 pm »
Yes there are two identical *two* temp senders... one for the dash gauge and one for the glow plug relay.
The fact that your dash gauge works with either suggests the senders are ok... pointing a finger at the glow plug relay.  It's programmed to come on for 20-30 seconds when very cold *or* if the sensor is disconnected.
Further details, pictures etc here:
http://vincewaldon.com/index.php?option=com_content&task=view&id=41&Itemid=28
« Last Edit: December 29, 2009, 05:17:18 pm by Vincent Waldon »
Reply #2December 29, 2009, 05:23:39 pm
ToddA1
  • 434
« Reply #2 on: December 29, 2009, 05:23:39 pm »
But as stated, the relay works properly when the blue/white wire is disconnected, just as the Bentley says it should.  I did count to about 20, then heard/felt it un-click.
Your write-up did answer the 2nd question, though.  Once the starter is engaged, the relay/GPs will shut off.
-Todd
Reply #3December 29, 2009, 05:47:10 pm
« Reply #3 on: December 29, 2009, 05:47:10 pm »
Yup, that's how it's supposed to work if it can't see the sensor.
However, it sounds like it's having trouble actually *reading* the sensor.
Reply #4December 29, 2009, 05:55:40 pm
ToddA1
  • 434
« Reply #4 on: December 29, 2009, 05:55:40 pm »
OK, I kinda get what you're saying, now.
I'll try cleaning the contacts, then run a jumper wire to see if that's the issue before I buy another relay.  I think I have a spare, but it would probably take longer to look/find it, than order one and have it delivered.
Thanks!
-Todd
Reply #5January 11, 2010, 08:14:21 pm
ToddA1
  • 434
« Reply #5 on: January 11, 2010, 08:14:21 pm »
I finally got around to trouble shooting this.  Replaced the terminal, then checked continuity...  everything reads good.  Guess I'll be getting a new relay.
-Todd
