Author Topic: timing 1.9D N/A 1Y motor????  (Read 2561 times)
December 26, 2009, 03:01:26 pm
professor
  • 14
« on: December 26, 2009, 03:01:26 pm »
i already search in this forum and i didn't found the pump timing for the 1.9 N/A... i found for 1.9TD, 1.9TD and 1.6 N/A. anyone knows the mm's for the 1.9 N/A?
Reply #1December 26, 2009, 09:02:50 pm
  • 1739
Re: timing 1.9D N/A 1Y motor????
« Reply #1 on: December 26, 2009, 09:02:50 pm »
I initially set mine at 1.00mm just to see. Was okay and started fine cold but real noisy. I then retarded it  without the gauge to what i thought was maybe .90 but after checking was at .85. Ran okay at both except harder to start cold. Now have a Giles pump set at .95.
Reply #2December 27, 2009, 05:09:57 am
professor
  • 14
« Reply #2 on: December 27, 2009, 05:09:57 am »
thks
1.00mm it's noisy and 0.95mm don't have noise?
what's a giles pump?
Reply #3December 27, 2009, 07:00:23 pm
  • 1739
« Reply #3 on: December 27, 2009, 07:00:23 pm »
Yes quieter now with the timing at .95 Check out http://www.performancediesel.ca/. His pumps are all over here. I'm still tweaking the fuel screw, but i figure i now have about 85-95 hp compared to the 75 it had before and the 60 that my original 1.7 had.
