VWDiesel Blog
Facebook Group
VWD on Twitter
General Information
Smoke Tales
Raced an 08 Audi S6 and won!
Pages:
Topic: Raced an 08 Audi S6 and won! (Read 10926 times)
Reply #30
July 07, 2010, 02:53:15 pm
rallydiesel
Re: Raced an 08 Audi S6 and won!
Reply #30 on:
July 07, 2010, 02:53:15 pm »
Beautiful fab work. What size external wastegate is that? What kind of boost and EMP's do you see? Are you planning on swapping the small turbo out for a vnt?
1991 Jetta TD - sold
2001 Golf TDI - Son's
Reply #31
July 10, 2010, 10:42:24 pm
lucasone
User+
Reply #31 on:
July 10, 2010, 10:42:24 pm »
I just replaced my small turbo with a VNT 17/22 and refabed every thing. I built this fancy lever that reverses the direction of the VNT control because I am using a boost actuator and not the vacuum actuator (MTDI). Any way to make a long story short I learned the hard way that I didn't need to reverses the direction of the lever. I went for a test run and it made very little boost (because the vanes were open instead of closed) until my second turbo made about 15 psi and moved the boost actuator to the closed position and the boost came on very strong and fast (50+psi) and I destroyed my new turbo. I broke the shaft in half and damaged both wheels. The turbo is getting rebuilt and I should have it all put together by the end of the month.
I have lots of new pictures that I will post as well. This time I am going to do some VNT control R & D before I bolt on the second turbo.
I will keep you posted.
Reply #32
August 16, 2010, 06:08:18 pm
Reply #32 on:
August 16, 2010, 06:08:18 pm »
Can i come up and see this car?
Blue 2009 CR140 Jetta CBEA/CJAA. Malone stage 2. EGR/DPF/Exhaust-valve deletes. 2.5" open exhaust. ADP Turbo swap. 1-stage nitrous kit.
THROWN ROD
Reply #33
August 16, 2010, 07:16:48 pm
greentdi
User+
Reply #33 on:
August 16, 2010, 07:16:48 pm »
Nice impressive work.
Reply #34
August 17, 2010, 02:40:53 am
lucasone
User+
Reply #34 on:
August 17, 2010, 02:40:53 am »
PM sent
Pages:
General Information
Smoke Tales
