Author Topic: Gasket-making material?  (Read 5049 times)
December 21, 2009, 08:41:14 pm
rallydiesel
  • 1880
« on: December 21, 2009, 08:41:14 pm »
Anybody have any leads on where I could find blank gasket sheet to make a custom gasket between turbine outlet and downpipe? I've got a wonky-flanged gt2559v with a 3 bolt turbine outlet that doesn't seem to match any common gaskets. Is it even possible to find blank gasket sheet for this? Since it's typically steel I may just need to find some tin or something.
I'll also need some more common-type material for a custom oil feed/drain fitting. Any advice?
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #1December 21, 2009, 08:52:08 pm
Re: Gasket-making material?
« Reply #1 on: December 21, 2009, 08:52:08 pm »
I used 1/4" hose and brass 1/8 pipe fittings for the oil feed line.
For the gasket maybe just make it out of a sheet of aluminum.
Reply #2December 22, 2009, 06:26:55 am
rallydiesel
  • 1880
« Reply #2 on: December 22, 2009, 06:26:55 am »
Great, thanks!
