turbo timer...?
by
79rabbit4dr
on 12 Dec, 2009 01:21
What are some good brands for turbo timers?
also thinking about remote start, suggestions?
#1
by
OM617
on 15 Dec, 2009 00:12
The best turbo timer is you. Wait 5 seconds before turning the engine off. Longer just wastes fuel.
#2
by
on 03 Jan, 2010 09:27
5 seconds? thats all? doesnt seem like a turbo and manifold could cool down in 5 seconds. or are you just saying 5 seconds just to let it spin down?
#3
by
on 03 Jan, 2010 11:32
When I had the turbo installed I waited until the egt gauge pegged at the bottom (250F) before shutting down, a little longer if I'd been running it real hard.
That method only measures the exhaust temp though so the turbo itself is probably really hot still.
#4
by
on 04 Jan, 2010 07:29
if the exhaust coming out was 250*, the turbo probably wasnt that ridiculously hot.
#5
by
OM617
on 05 Jan, 2010 19:04
Diesel exhaust is far cooler than g@ssers. 5 seconds is more than enough to make sure its cool and at its lowest speed.
#6
by
blackdogvan
on 05 Jan, 2010 21:42
While the gasses may be cooler after 5 seconds, I don't think that's long enough to cool a heat soaked turbo. Its the latent heat from your exhaust manifold & turbine housing that cokes the oil in the journal bearings after you shut down & the oil isn't flowing.
So... buy a house at the bottom of a hill & never buy a turbo'd car from someone who lives at the top of one!
#7
by
on 05 Jan, 2010 21:50
Hahaha......that's what I was trying to say
#8
by
on 07 Jan, 2010 11:17
i usually liked to idle my car for around 30 seconds to a minute usually. i never had a EGT gauge, so i figured i might as well be safe and idle it down good.
