Author Topic: First time injection pump removal  (Read 1958 times)
December 09, 2009, 09:32:56 pm
silvertdvw
  • 38
« on: December 09, 2009, 09:32:56 pm »
I am going to remove my ip to replace the cold start o-ring. when I remove the ip am I going to have to redo the timing after I put it back on or is the timing only changed when you do something internally.
Reply #1December 09, 2009, 09:51:51 pm
Possum79
  • 276
    • http://www.poscarclub.com
Re: First time injection pump removal
« Reply #1 on: December 09, 2009, 09:51:51 pm »
Timing will be changed as soon as you loosen the bolts mounting it. get yourself a dial gauge to put it all back together.
1979 VW Rabbit Diesel L
Reply #2December 10, 2009, 01:06:09 am
« Reply #2 on: December 10, 2009, 01:06:09 am »
I think you can do that on the car.
take off the nut
lockwasher, and
then the arm
a washer behind there
hides the o ring.
Reply #3December 10, 2009, 09:48:28 am
« Reply #3 on: December 10, 2009, 09:48:28 am »
you have to pull the arm and the aluminum piece it mounts in to change the cold start shaft o ring. you can pull that piece off on the car too tho.
