Author Topic: engine injector pumps  (Read 5358 times)
December 08, 2009, 05:26:56 am
sabatino
« on: December 08, 2009, 05:26:56 am »
hello, asks for assemblage engine i.p (injector pumps) tdi in mk1
suggestions?
which transmission?
how to climb on centralina?
I hope you understand me, you write you have not understood thanks.  :)
Reply #1December 08, 2009, 08:31:04 am
gigaz2
  • 626
Re: engine injector pumps
« Reply #1 on: December 08, 2009, 08:31:04 am »
mate, this subject has been more than covered, in fitting it to a mk1 the only issues are with interference with other components, injection pump is the same size as a TD one, so it fits
Reply #2December 08, 2009, 08:48:25 am
gigaz2
  • 626
« Reply #2 on: December 08, 2009, 08:48:25 am »
here is the thread that answers your question about the pumps:
http://www.vwdiesel.net/forum/index.php?topic=6427.0
Reply #3December 12, 2009, 11:57:15 pm
sabatino
« Reply #3 on: December 12, 2009, 11:57:15 pm »
to install pd in mk1?   :)
is it more' clear question?
all the suggestions? ???
Reply #4December 13, 2009, 11:02:28 am
rallydiesel
  • 1880
« Reply #4 on: December 13, 2009, 11:02:28 am »
Oh a PD? I'm not sure anyone has put a pd into a mk1. You'd have a lot of engine mount mods to do. The pd mounts are on the sides and a dogbone mount on the bottom which connects to the rear subframe. As far as I know, this is completely different than on a mk1.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #5December 14, 2009, 04:52:21 am
sabatino
« Reply #5 on: December 14, 2009, 04:52:21 am »
ok, but I have seen pd on mk1 on http://forums.vwvortex.com   ???
some suggestions for ecu? (electronics)   ???
does it modify pomp pd to pr?possible?   ???
other suggestions?
all the suggestions I accept from all of you you are numbe one   ;D ;D ;D
thanks to you.
Reply #6December 17, 2009, 11:37:46 pm
Street Toys
« Reply #6 on: December 17, 2009, 11:37:46 pm »
I know someone who has done this here in the US It isn't too difficult.
What size PD are you wanting to use PD-150? even the little 1.4 AMC engine code
Lupo or polo would be cool in a MarkI.
Just use the EDC-15+ ECU and it will go together pretty good. ;)
Reply #7December 18, 2009, 12:40:56 pm
sabatino
« Reply #7 on: December 18, 2009, 12:40:56 pm »
also 130 pd is ok
other suggestions?
EDC-15+ ECU as it connects?
do I install scheme?
Reply #8December 20, 2009, 10:11:48 am
sabatino
« Reply #8 on: December 20, 2009, 10:11:48 am »
Reply #9December 20, 2009, 03:31:52 pm
Street Toys
« Reply #9 on: December 20, 2009, 03:31:52 pm »
Bonjourno Sabatino,
  Yes, A PD-130 would not be very hard either.  Is that an engine of choice or do you have one already?
You see, you are very lucky to be there because there are many parts available to you that we don't have here in the USA! ;)
  Regardless of which 1.9, 8 valve PD engine you choose, you can use the engine wiring harness from the European model to make that engine work in almost anything! A complete doner car will make it much easier for you if you choose to use the gauge cluster/dash.  You would have all the wiring there to work with! Transmission and all the other goodies will be there to. ;)  Myself, if I were to do such a project, I would be looking for a PD 150 car!! for power, you could make 250HP without too much trouble. or if you really want economy you could get about 90MPG with a 1.4l lupo motor! :D
Reply #10December 21, 2009, 04:57:15 am
sabatino
« Reply #10 on: December 21, 2009, 04:57:15 am »
ahahah ok,tank you   ;D
no saving    ;D
to make good car   :P
do I want pd 150 but the ecu?   ???
how assemblage?   ???
which change?   ???
which suggestions?  ??? ??? ???
it worries only the ecu  ??? no the mechanics   ;D
help me you if you are able  :D
if it serves to you exchange I can send  ;)
Reply #11December 21, 2009, 07:20:18 pm
rallydiesel
  • 1880
« Reply #11 on: December 21, 2009, 07:20:18 pm »
You're going to need the entire pd wiring harness. Including the instrument panel. I hope you are good with vagcom and wiring. It would be a headache of epic proportions. Good job if you can succeed.
Reply #12December 22, 2009, 05:11:28 pm
Street Toys
« Reply #12 on: December 22, 2009, 05:11:28 pm »
In a perfect world, yes it is the easiest way to go.  However, you can make the PD engine run though and monitor everything that you want...oil pressure, water temp tach, EGT's (even manifold pressure if you like) and re-flash the ECU with both an immobilizer delete and "cluster-delete" also so it's only function is strictly "basic"engine/throttle managment.  Kind of like we did here on our dual VW lupo PD-75 drilling rig!
http://www.streettoys2000.com/proddetail.php?prod=drillingrig
on the hydrologic side it is still basically "stock" 75HP and the "air-compressor side" is running about 120HP smoke free.  This works with NO VW gauges.  ;)
« Last Edit: December 28, 2009, 08:18:05 pm by Street Toys »
Reply #13December 22, 2009, 05:23:29 pm
Street Toys
« Reply #13 on: December 22, 2009, 05:23:29 pm »
no saving    ;D
to make good car   :P
how assemblage?   ???
which change?   ???
Like I said earlier, the EDC-15+ is really easy to get where you live in Europe and it is really not that difficult to modify if you know a good tuner.  Many tuners in Europe are light years ahead of MOST American chip tuners.  Sadly, I don't know any in Italia but there are some very, very good German, Slavakian,  Polish, Swedish, Danish, and Norwegian tuners that could help you too!
Reply #14December 24, 2009, 10:20:36 am
sabatino
« Reply #14 on: December 24, 2009, 10:20:36 am »
wow,ok address?
give me more infos:
1) engine
2) EDC-15+ ECU
3) trasmission?
4) pedal gas, brake, etc?
how much thing other?
GOOD CHRISTMAS Á EVERYBODY
