Author Topic: AAZtd into 1985 MK2 gasser,ACN trans what clutch/flywheel  (Read 8011 times)
December 06, 2009, 06:25:35 am
scraperhand
  • 5
« on: December 06, 2009, 06:25:35 am »
Hi All,
first post,putting a aaz td into my old golf mk2,i want to use the acn code trans as i like the ratios,do i need to use the gasser clutch flywheel or just change the clutch disc to match splines,thanks for any help
Reply #1December 06, 2009, 09:51:49 am
Re: AAZtd into 1985 MK2 gasser,ACN trans what clutch/flywheel
« Reply #1 on: December 06, 2009, 09:51:49 am »
I think the splines are the same. I'm pretty sure that is exactly what I have in my car. I keep forgetting my tranny code for some reason though.
Keep the diesel flywheel. TDC isn't marked on the gasser one. It's 8 degrees off or something to that effect.
You'll probably hate the ratios with the AAZ though. Mine is NA and I find them too short.
Reply #2December 06, 2009, 10:34:50 am
« Reply #2 on: December 06, 2009, 10:34:50 am »
99% sure you will want to take everything from the aaz and put it on the acn.  I bought a 1.9 flywheel to put on my 1.6TD as it has a larger diameter and should have more holding power. I believe you want a 210mm clutch setup with the small 24 spline hub
Reply #3December 06, 2009, 11:03:14 am
rallydiesel
  • 1880
« Reply #3 on: December 06, 2009, 11:03:14 am »
ACN is about as good as you'll get for an 020. I've got a 4S 020 and it sucks above 80 km/h because it's geared too short and the 4S is an oem diesel trans. If you popped a .71 fifth in the ACN you'd have probably the best 020 diesel ratios.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #4December 06, 2009, 04:18:34 pm
scraperhand
  • 5
« Reply #4 on: December 06, 2009, 04:18:34 pm »
Thanks for the replies,ive got a ff with the .71,might just raid it for fifth gear,looking forward to getting the beast on the road.
Reply #5January 11, 2010, 04:38:29 pm
scraperhand
  • 5
« Reply #5 on: January 11, 2010, 04:38:29 pm »
Finally enough time to work on my car,the thing is on the azz the flywheel bolts to the crank instead of the other way round like the 8 valve tha was in it,any suggestions,plz
Reply #6January 11, 2010, 07:51:21 pm
« Reply #6 on: January 11, 2010, 07:51:21 pm »
This, http://www.scirocco.org/gears/ says the stock FF and ACN are the aaalmooost the same in fifth gear, at 5000rpm the FF will go 125mph and the ACN will go 126mph, the ACN with a .71 fifth will go 133mph.
Almost not worth the effort of swapping fifth gear.
Reply #7January 11, 2010, 08:35:27 pm
« Reply #7 on: January 11, 2010, 08:35:27 pm »
Your AAZ came from a Passat then with a 02A tranny. You can get the AAZ clutch setup that is the same as the 020
Reply #8January 12, 2010, 03:16:40 am
Patrick
  • 1034
« Reply #8 on: January 12, 2010, 03:16:40 am »
Tyler is right. I'm running a stock diesel 210 mm clutch ('93-'93 mk3 golf/jetta) on an AAZ in my 92 jetta with an 020 trans. Other option (using in the one I'm building) is a 16V pressure plate with the 8V gasser disc with the diesel flywheel. Supposed to be good for more torque.
Reply #9January 12, 2010, 04:58:54 am
scraperhand
  • 5
« Reply #9 on: January 12, 2010, 04:58:54 am »
Ok got it,can i use any diesel flywheel or does it have to be aaz 020 specific,thanks again
Reply #10January 12, 2010, 10:09:26 am
« Reply #10 on: January 12, 2010, 10:09:26 am »
well, if the flywheel mounts to the crank, you cant use it.
if the flywheel bolts to the pressure plate then the crank, you can use it.
Reply #11January 12, 2010, 07:09:58 pm
« Reply #11 on: January 12, 2010, 07:09:58 pm »
Just make sure that whatever flywheel you use has the proper TDC mark on it. Gas ones don't always
Reply #12January 14, 2010, 10:22:41 am
« Reply #12 on: January 14, 2010, 10:22:41 am »
if you are good enough, you can scribe a proper mark on a gasser wheel tho. and they are MUCH lighter.
