Author Topic: engine codes  (Read 5916 times)
October 14, 2005, 01:43:08 am
flyfishharry
  • 2
engine codes
« on: October 14, 2005, 01:43:08 am »
I must admit that I am a total newby to VW diesels, and to the forum, but here it goes...I bought a 1981 Caddy with newly installed crated 1.9 motor out of Canada.
Where can I get codes to tell me what the motor is ?? Eco, IDI etc....What stock vehicles did these motors apply to (ie.years and models), so when I need to get parts, which vehicle do I reference?
Thanks for any advice
New to the group
81 caddy 1.9 IDI
Volvos many
Reply #1October 14, 2005, 05:58:00 am
BlackTieTD
  • 1512
engine codes
« Reply #1 on: October 14, 2005, 05:58:00 am »
does it have a turbo? likely AAZ engine code  :)
as far as vehicles... passats, golfs, jettas... 93-98ish i don't know exact years. you should be fine saying "1995 Jetta turbo diesel"
Reply #2October 14, 2005, 06:22:56 am
dieselweasel
  • 312
engine codes
« Reply #2 on: October 14, 2005, 06:22:56 am »
Yeah it's likey an AAZ, which is an IDI engine.  Unfortunately you won't find any US cars with that engine since it was only available in Canada.  Maybe you're near the border and could find parts in BC.  As mentioned, Golfs, Jettas, Passats came with this engine from '93-'98 I think.  They brought in the TDi in '96 on the Passat.
Reply #3October 14, 2005, 07:29:44 am
Maarten
  • 339
engine codes
« Reply #3 on: October 14, 2005, 07:29:44 am »
Check the sticker on the distributioncover or on check the enginecode below/between the cyl 2 and 3 injectors.
Audi A3 TDI '98
VW cabby '79
VW T3 1.9TD '91
Reply #4October 19, 2005, 09:22:43 pm
flyfishharry
  • 2
engine codes
« Reply #4 on: October 19, 2005, 09:22:43 pm »
Thank you all .....I will check it out further.  There is no turbo on the engine, but it looks like it is set up for one.  I would like to install one later.
New to the group
81 caddy 1.9 IDI
Volvos many
Reply #5October 19, 2005, 11:50:13 pm
935racer
engine codes
« Reply #5 on: October 19, 2005, 11:50:13 pm »
Hey post up some pictures of your engine bay and let us know the engine code, if it is an AAZ and has a turbo pump than you are a good candidate for some turboing! If you need either bolt on or custom modifcations I run a shop just across the border in Canada specializing in turbo diesel modifications. Also do lots of searchign on this site, there is tons of awesome information!
Reply #6April 19, 2006, 06:16:25 am
Katmandu
  • 47
engine codes
« Reply #6 on: April 19, 2006, 06:16:25 am »
Quote from: "Maarten"
Does anyone have a listing of the engine codes that were available for the 1.5/1.6 Diesel engines ??
Reply #7April 19, 2006, 06:52:07 am
Katmandu
  • 47
engine codes
« Reply #7 on: April 19, 2006, 06:52:07 am »
Quote from: "Katmandu"
 Just found this....
 http://www.4crawler.com/Diesel/index.shtml#EngineSpecs
Reply #8April 19, 2006, 09:49:06 pm
fspGTD
  • 1529
engine codes
« Reply #8 on: April 19, 2006, 09:49:06 pm »
Moved to General.  Not IDI engine / power enhancement related.
Jake Russell
