Author Topic: ABA intake manifold  (Read 5286 times)
December 02, 2009, 03:57:42 pm
54321chris
ABA intake manifold
« on: December 02, 2009, 03:57:42 pm »
Possibly a dumb question, but I have one sitting around.  Would the wraparound-style 2.0 intake off an ABA be any kind of upgrade?  Is it even usable?  Seems like replacing the intake manifold is a common upgrade, and I'm getting ready to pipe an intercooler, so I want to get it all done at the same time.
Reply #1December 03, 2009, 10:25:54 am
kaneb
  • 164
    • www.dasdubbers.org
Re: ABA intake manifold
« Reply #1 on: December 03, 2009, 10:25:54 am »
The intake on an aba(2L) has the intake ports on the front of the engine, not the back like on the diesels.   I don't know if you could even flip the mani around to fit?  I think the turbo would be in the way...
2004 Tdi sport-daily
1983 Rabbit TD-go kart
www.dasdubbers.org
Reply #2December 03, 2009, 10:26:51 am
« Reply #2 on: December 03, 2009, 10:26:51 am »
the ports on the head are totally different and spaced differently, so even if it would clear the turbo, it still wont bolt up.
Reply #3December 03, 2009, 02:35:19 pm
« Reply #3 on: December 03, 2009, 02:35:19 pm »
sdi intake does that.  i have one but they won't work on a td, they might work on an na, i dunno tho
Reply #4December 03, 2009, 03:25:36 pm
truckinwagen
  • 1895
« Reply #4 on: December 03, 2009, 03:25:36 pm »
if I remember right the SDI will clear an NA pump, but for a turbo application, even if it did clear the turbo pump, its made of plastic.
there are a few TDI guys who have blown them apart by running boost through them.
83 Opel Kadett Diesel
Reply #5December 04, 2009, 09:32:07 am
« Reply #5 on: December 04, 2009, 09:32:07 am »
its a good lookin intake, just too bad its plastic.
Reply #6December 04, 2009, 12:24:54 pm
Turbinepowered
  • 1206
« Reply #6 on: December 04, 2009, 12:24:54 pm »
Someone should mold it and cast it.
Reply #7December 04, 2009, 04:26:28 pm
« Reply #7 on: December 04, 2009, 04:26:28 pm »
i never heard of them blowing up, i wouldn't be concerned with that any way tho, lots of boosted cars have plastic intakes
Reply #8December 04, 2009, 09:53:35 pm
RadoTD
  • 513
    Stage WTF
« Reply #8 on: December 04, 2009, 09:53:35 pm »
I'd be more afraid of the plastic melting being so close to the turbo
enough boost is when you have 3 dimple marks in the hood from the valve cover nuts..  ;D
Reply #9December 04, 2009, 10:11:03 pm
cyrus #1
  • 360
« Reply #9 on: December 04, 2009, 10:11:03 pm »
I wouldn't be concerned about it melting.  I'm sure they were smart enough to use a thermoset plastic.  In which case it won't be melting.
Cody
2002 Jetta TDI
2000 Jetta TDI - R.I.P.
Reply #10December 04, 2009, 10:19:54 pm
truckinwagen
  • 1895
« Reply #10 on: December 04, 2009, 10:19:54 pm »
well, to be honest, most of the burst SDI intakes were running pretty high boost numbers.
the heat certainly weakened the plastic and the 35+ PSI was too much for it.
more than likely it would be fine at lower boost pressures, but the interference with the turbo pump kinda ruins it anyway.
Reply #11December 05, 2009, 04:47:30 am
« Reply #11 on: December 05, 2009, 04:47:30 am »
ha yeah it really really ruins it, i was pretty disappointed
