Author Topic: Need wiring diagram for 1.9TD (cut ground cable, pic inside)  (Read 4936 times)
November 30, 2009, 12:39:58 pm
MatLax
  • 13
« on: November 30, 2009, 12:39:58 pm »
When I turn the car on or if I put my key on accessories, the cluster turns off, only the turning lights signals still work, it has nothing to do with the radio because if I go back at the key's first position the radio stays on and the cluster comes back from the dead... The only clue I have so far is a cut ground wire on the driver's side of the engine (small cable, not the big ground going to the battery)... Someone has the wiring diagram for a 1.9TD (it's in a 1997 Golf without AC)?
Here's the cable (at the bottom in between the center and the right corner), I know it was connected to something before, I just don't remember where...
edit: changed the title
« Last Edit: December 01, 2009, 06:01:45 am by MatLax »
Reply #1December 02, 2009, 09:55:18 pm
MatLax
  • 13
Re: Need wiring diagram for 1.9TD (cut ground cable, pic inside)
« Reply #1 on: December 02, 2009, 09:55:18 pm »
Soooooooooooooooooo.... nobody can at the very least check in their 1.9TD enginebay to see where this ground cable goes to?
Reply #2December 03, 2009, 03:22:16 am
Makebeleaf
  • 57
« Reply #2 on: December 03, 2009, 03:22:16 am »
I'll take a look this morning for you....soon as the sun comes up!
Reply #3December 03, 2009, 05:37:20 am
Makebeleaf
  • 57
« Reply #3 on: December 03, 2009, 05:37:20 am »
Here you go....Neg wire goes into wiring harness behind Cluster.
Looks like you need a Valve cover Gasket also....leaking quite a bit of oil onto engine.
Reply #4December 03, 2009, 11:11:45 am
MatLax
  • 13
« Reply #4 on: December 03, 2009, 11:11:45 am »
Yeah, was leaking before, but now it's just dirty because I never cleaned it after changing the gasket :p
It's strange, I don't have any other black cable this size that's cut on the big round connector (the one on your picture), unless the cable disconnected itself directly at the connector, I'll go take a look
Reply #5December 03, 2009, 12:28:11 pm
MatLax
  • 13
« Reply #5 on: December 03, 2009, 12:28:11 pm »
Problem solved, thanks! The smaller black cable was the one connecting to the bigger black cable, go figure...
