S-PAutomotive.com
Author Topic: When checking your oil...  (Read 1636 times)
November 25, 2009, 03:13:18 am
  • 3468
    • McScrubbins Body Wash
« on: November 25, 2009, 03:13:18 am »
Always check that your dipstick tube is tight in there!!!
I must have knocked mine loose because when i started it to drive out of the garage to go race up the mtn to seat the rings WOW there was a lot of oil on the ground. roughly 3 litres of it.
a whole bag of cat litter later ....
so always check it's not loose!!!!!!!!!!!!!!!!!!!!!!!!
horrendous mess to clean
Reply #1November 25, 2009, 10:36:41 am
Re: When checking your oil...
« Reply #1 on: November 25, 2009, 10:36:41 am »
and if its loose and you spool the turbo, say hello to a even bigger mess... i took and made a dip stick and tube for my car to get rid of the problem of oil coming back out the dip stick. i had an ancient 1.5 block with no dip stick tube, so it wouldnt seal very good with just the felt gasket.
Reply #2November 25, 2009, 12:13:30 pm
GEE-BEE
  • 1604
« Reply #2 on: November 25, 2009, 12:13:30 pm »
USE YOUR DIPSTICK JIMMY !  ;D
Gee-Bee
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #3November 25, 2009, 12:41:07 pm
« Reply #3 on: November 25, 2009, 12:41:07 pm »
haha, good one!
Fixmyvw.com
