Author Topic: Micro controlled VNT project  (Read 34353 times)
Reply #45May 14, 2010, 03:34:43 pm
regcheeseman
  • 714
Re: Micro controlled VNT project
« Reply #45 on: May 14, 2010, 03:34:43 pm »
The VNT controller servo is now responding to servo feedback and throttle position.
As a fair few people have suggested it, I've written the code in for a shift light.
Meanwhile, back in the workshop, the proper engineering carries on....
Front end, my IC fun wasn't completely wasted. ;) Shame about the dog poo bags!
One manky gearbox tidied up
Block well on the way (WAITING FOR GIRDLE!!!!!)
Marked up the manifolds for some port matching and a bit of flow work.
Finally - toys. mmmmwahahahahahahahahahahaha  :)
1Y/AAZ head, 1Y manifold, MK4 VNT turbo, MLS gasket, ARP studs
I've been painting more bits this evening and putting a few bits together, then I got the carbide burrs out and the hacksaw and ruined my manifold....
Don't worry all will be fine!
Reply #46May 14, 2010, 08:01:25 pm
« Reply #46 on: May 14, 2010, 08:01:25 pm »
IDK if the mani is as tough as the D24 that I ported, but if so good job. The 1.6L TD intake was like butter compared to the D24. Looks great keep up the good work.
Reply #47May 18, 2010, 04:28:10 am
regcheeseman
  • 714
« Reply #47 on: May 18, 2010, 04:28:10 am »
Started to attack my ports with a carbide burr in a drill (gave up on the die grinder and the dremel)
Was taking ages, then I found a milling cutter and whacked that in the drill - that sorted it!
Then I got a abrasive disc in my grinder and sorted that inlet manifold out - just have to get the holes welded up.
Reply #48July 16, 2010, 10:45:46 am
« Reply #48 on: July 16, 2010, 10:45:46 am »
Updates???  :D
Reply #49August 16, 2010, 09:30:30 am
erice1984
  • 263
« Reply #49 on: August 16, 2010, 09:30:30 am »
I think BlueMule might have been confused, Turbos are load dependent not RPM dependent.
1980 Rabbit 1.9TD
Reply #50August 16, 2010, 03:58:07 pm
regcheeseman
  • 714
« Reply #50 on: August 16, 2010, 03:58:07 pm »
not a massive amount to update really, but the project has changed a lot, I've tested the mark one PCB as far as it will go and to be honest am not happy.
Mark two has been designed and coded and now I'm on mk 3 using different technology to improve the inputs and the speed. I've ditched the complex config mode and implemented a shift light.
I've lost the multi stage boost limits and switched to a simpler single 'power factor' which shifts the boost map up or down.
This streamlines the code with no detrimental effect on functionality
I've also designed the adaptor to run the mk1 speedo from an electronic gearbox pick-up
Meanwhile the car got painted, the paint reacted, was stripped and is ready for re-painting.
Oh and I also swapped my daily from a ford to a VW - and then modified that.
When I get some real usable results or pictures, you will know!
Reply #51August 17, 2010, 01:52:02 pm
monomer
  • 414
« Reply #51 on: August 17, 2010, 01:52:02 pm »
Reg,
Besides the controller, can you give off a parts list of the turbo, actuator and the like?
I'm just looking at going turbo and I'm going to go straight for this!
www.michiganvw.org
Reply #52August 19, 2010, 03:06:13 am
regcheeseman
  • 714
« Reply #52 on: August 19, 2010, 03:06:13 am »
The turbo is a BV?39 I think - from a mk4 golf
The actuator is a power valve assembly from an NSR 250 - with custom made fitting at the turbo end, actuation is remote via bowden cables
TPS sensor is just a quality potentiometer attached to the accelerator pedal
The system I'm designing should have enough adjustability to work with any VNT.
Reply #53August 24, 2010, 02:03:42 pm
regcheeseman
  • 714
« Reply #53 on: August 24, 2010, 02:03:42 pm »
And the prize for the most over engineered throttle position sensor......
I originally stuck the sensor on the throttle pedal shaft but only got 30 degrees of rotation which would give poor resolution so I messed around with cogs and gears and the found a drive mech from a drug infusion pump going for scrap.
transfers the 30 degrees to nearly the 270 of the sensor - the rest is compensated for by electronic wizardy.
Reply #54August 24, 2010, 02:30:51 pm
VW_Commuter
  • 355
« Reply #54 on: August 24, 2010, 02:30:51 pm »
That is sooooo cool.
Greg
'06 Golf TDI traded in for a '12 Jeep Rubicon (the Phatbox is available)
'91 Jetta TD, a work in progress (I'll do a build thread when I start in earnest)
'65 Notchback, a project not yet started
Reply #55November 07, 2010, 01:33:58 am
tomnik
  • 10
« Reply #55 on: November 07, 2010, 01:33:58 am »
Hi,
regcheeseman, will your VNT controller be available to buy (as a complete set or parts and code)?
Did you get it to a final version?
Tom
Reply #56November 09, 2010, 02:49:47 am
regcheeseman
  • 714
« Reply #56 on: November 09, 2010, 02:49:47 am »
I'm intending to make five boards, four to sell, I will also bundle notes, schematics, PCB artwork, parts listings, Microprocessor code etc into a package for free.
I'm not quite at that stage yet. The second revision of the board was taken to the developers last week.
Hopefully have it working properly in the new year.
Reply #57November 09, 2010, 02:06:40 pm
Baxter
« Reply #57 on: November 09, 2010, 02:06:40 pm »
Do you have a bird? you have way too much time on your hands...
 :P
Well done so far, smart arse...
Reply #58November 09, 2010, 02:09:53 pm
Alcaid
  • 549
« Reply #58 on: November 09, 2010, 02:09:53 pm »
These two PCBs are around the same size as an EDC15 ECU. Maybe a bit over engineered for the simple job it is going to do?  ;)
'10 VW Passat 1.6TDI Highline
Reply #59November 09, 2010, 03:14:06 pm
« Reply #59 on: November 09, 2010, 03:14:06 pm »
I would want you to sell these eventhough I don't have a VNT yet. I think I love you a little...no homo
