Author Topic: running thicker fuel advances timing?  (Read 7776 times)
Reply #30November 25, 2009, 09:59:29 am
dennis
  • 311
Re: running thicker fuel advances timing?
« Reply #30 on: November 25, 2009, 09:59:29 am »
Gonna lower the pressure on my Volvo this weekend. Gave that pin a smack already, and have had remorse every since.
1980 Caddy TD (Always in progress)
1983 Volvo 245 D24 NA Building D24T
1980 Air-cooled Westy
1956 F100 (What to do???))
Reply #31November 25, 2009, 12:11:41 pm
dennis
  • 311
« Reply #31 on: November 25, 2009, 12:11:41 pm »
No kidding, and I do this for a living too. But.. I have milked a couple of past Rabbits into running smoother, while reducing white smoke. At the end of the day internal pressure problems usually indicate a worn pump. As far as measuring pressure while adjusting, it is difficult to calibrate a hammer blow to a punch. Just need to modify a socket to git that valve out and get out the ole hammer, and punch and go the other way. Wonder why Bosch didn't put a screw there instead of that pin.
Reply #32November 25, 2009, 12:59:33 pm
« Reply #32 on: November 25, 2009, 12:59:33 pm »
My guess... same reason the fuel screw has a steel collar welded to it... "if you have to ask, don't touch".  ;-)
There *is* a Bosch-specific tool that attaches to the top of the pump and allows you to gradually increase the internal pressure upwards... unfortunately it remains a one-way adjustment however.
Reply #33November 25, 2009, 02:23:12 pm
dennis
  • 311
« Reply #33 on: November 25, 2009, 02:23:12 pm »
Yeah, I know but I must touch it. Got lots of part to put on the Caddy this week end. Im gonna outright molest the pump on it
« Last Edit: November 25, 2009, 02:40:16 pm by dennis »
Reply #34November 29, 2009, 05:44:32 am
vwjones
  • 80
« Reply #34 on: November 29, 2009, 05:44:32 am »
hi rabbit,
I run a two tank system on my 1.6.  one has diesel and the other has a mixture of 4/5 used motor oil, 1/5 kerosene or diesel, one ounce acetone per 5 gal fuel, one ounce seafoam per 5 gal to prevent carbonization, and filter it down to one micron.  I start it up and get it up to temp on the diesel, then switch over to the used oil by turning two 3 way valves in the cockpit.  the oil is routed through a flatplate fuel heater that I got off ebay for about 74 bucks.  If I don't wait for the engine to get up to temp, it doesn't run worth a *** on the oil.  I suppose it is somehow related to the thickness of the fuel as well since the flatplate heater thins it out alot. Might be worth a try for you.  BTW.  when I switch it over on the highway, speed increases when the mixture hits the engine even though i don't change the accelerator position.  It sounds a lot quieter too.  I switch back to diesel before I shut it down too.  I've ran about 6k on this mixture so far with zero problems.  I only need to buy a tank of diesel about every 3 thousand miles  ;D
