better turbo!
Pages:
Topic: better turbo! (Read 7401 times)
Reply #15
November 19, 2009, 08:45:15 am
anto
Re: better turbo!
Reply #15 on:
November 19, 2009, 08:45:15 am »
If gas/petrol was the same price here as it is over there we'd be driving them too lol
Reply #16
November 19, 2009, 09:06:13 am
55eta
Re: better turbo!
Reply #16 on:
November 19, 2009, 09:06:13 am »
xud 212 type pump is 10mm but agree with the solenoid been down that road to much elec tricery in the end just used the head after alot of messing around and apiss poor out come
Reply #17
November 19, 2009, 09:10:19 am
anto
Re: better turbo!
Reply #17 on:
November 19, 2009, 09:10:19 am »
What engine did that pump come on the 406?
I thought the 2.1 engine was a lucas pump?
Any 406 pumps ive opened have been 9mm heads and theyve all been off the 1.9 turbo diesel.
Reply #18
November 19, 2009, 11:37:16 am
55eta
Re: better turbo!
Reply #18 on:
November 19, 2009, 11:37:16 am »
it came of 406 1.9td on a 99 ,your right the 2.1 are lucas pumps but there is a chance some one had got at the 1.9 pump as it was scraped because it would not get through the emissions test but they do use three different pumps on the 1.9s xud212 xud bpo2 and the xud which is a lucas pump.The solenoid on the side off the pump did go to a small ecu but don't that take its signal of the CTS sensor to adjust the advance on cold starting? or do they use MAPS+road speed sensors as i am certain it did not have a air flow meter on it and would have thought it would need them in conjunction with a crank angle sensor to have a effective electronic dynamic advance system?I know the late aaz pumps had a type of electronic control but they had a start of injection censor like on the TDIs,{ where you would screw your dti gauge in on the idi pump }but it did not have one of them on the pug pump
Reply #19
November 19, 2009, 03:31:20 pm
55eta
Re: better turbo!
Reply #19 on:
November 19, 2009, 03:31:20 pm »
looking at the wiring diagrams for the 406 the pump i had of the scraper could not have been the original pump as they show three plugs not including the immobilizer/fuel shut of obviously the reason it was scraped so do not know what its of but its 10mm
only used the head in the end on a 405 body
Reply #20
November 20, 2009, 01:02:07 am
anto
Re: better turbo!
Reply #20 on:
November 20, 2009, 01:02:07 am »
I did the same with a 406 pump i had (9mm).
I had a citroen xsara 1.9 pump with bad internals so used the casing (no solenoid) and the good 9mm internals of the 406 and job done.
Ive now got an 11mm head from a transit set to go back on soon as i had a few teething problems.
Reply #21
November 24, 2009, 12:50:07 pm
Mozza
Re: better turbo!
Reply #21 on:
November 24, 2009, 12:50:07 pm »
sorry this is an old thread but how can i tell which turbo my aaz engine has as stock, as i think im going to stick with it either way, i have fitted the mk2 intercooler and am sticking with that to as i want a propper factory look under the bay, I think i would be happy with 110 bhp any how as this aint a race car its my daily!
Reply #22
November 24, 2009, 03:34:12 pm
55eta
Re: better turbo!
Reply #22 on:
November 24, 2009, 03:34:12 pm »
there should be a ID plate on the cold side{compressor} but what ever turbo it is as long as it is working ok it should be ok for 110bhp but you may struggle with a stock aaz pump
Reply #23
November 24, 2009, 04:34:17 pm
55eta
Re: better turbo!
Reply #23 on:
November 24, 2009, 04:34:17 pm »
@ anto are you using the xsara pump on a vw engine
Reply #24
November 25, 2009, 01:59:52 am
anto
Re: better turbo!
Reply #24 on:
November 25, 2009, 01:59:52 am »
55eta - no, i am using it on a peugeot 306, same engine just different body...
Reply #25
November 25, 2009, 05:05:23 am
Mozza
Re: better turbo!
Reply #25 on:
November 25, 2009, 05:05:23 am »
i will be putting the gtd nozzles on and a rover boost pin, which should help a little!
Reply #26
November 25, 2009, 06:28:49 am
MJF
Re: better turbo!
Reply #26 on:
November 25, 2009, 06:28:49 am »
Whats different with Peugeot pumps? 150hp from governormodded&pinned AAZ pump is no problem.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #27
November 25, 2009, 09:03:16 am
anto
Re: better turbo!
Reply #27 on:
November 25, 2009, 09:03:16 am »
MJF - different pump noses i think so maybe wouldnt fit without mods.(never seen a vw pump in real life though)
Internals should be similar though so id expect the same performance. Peugeot pump has the good aneroid pin as well.
Reply #28
November 26, 2009, 12:33:48 am
smokin_fun
Re: better turbo!
Reply #28 on:
November 26, 2009, 12:33:48 am »
Do yourself a favor and get giles to mod a pump for you...wtih the upgraded turbo, IC and bigger straight piped exhaust you will enjoy your daily driver ALOT more! (BTW techtonics tuning make great DP's and exhausts)
My daily driver has one (45,000 kms since install) and i love every minute of every drive..... i still have the stock tape deck! Its that good to listen to the sound this makes anytime its over 10psi.
if you're swappen turbos anyways you should think about a ball bearing setup.
Pages:
better turbo!
