Author Topic: better turbo!  (Read 7425 times)
November 16, 2009, 08:20:13 am
Mozza
  • 81
better turbo!
« on: November 16, 2009, 08:20:13 am »
what would be an easy turbo upgrade for the standard 1.9 aaz turbo and easy enough to come buy!
I would like to run it at about 130bhp so nothing silly but want to worry some people,
Reply #1November 16, 2009, 08:33:38 am
GEE-BEE
  • 1604
Re: better turbo!
« Reply #1 on: November 16, 2009, 08:33:38 am »
K03 hYBRID frpm GPOPSHOP
2.5 downpipe
308 injectors from brickwerks ( GTD )
Rover Pin : Brickwerks also
Giles pump OHC
EGT/ PSI Gauge from Mcnally.com
Iam doing the same...
« Last Edit: November 16, 2009, 08:38:31 am by GEE-BEE »
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #2November 16, 2009, 09:33:34 am
Re: better turbo!
« Reply #2 on: November 16, 2009, 09:33:34 am »
If you are getting a pump from Giles don't waste your money on a boost pin.
Reply #3November 16, 2009, 01:02:25 pm
4wheeler
Re: better turbo!
« Reply #3 on: November 16, 2009, 01:02:25 pm »
don`t waste money on any K03 either.
K14 or bigger..
Reply #4November 16, 2009, 02:28:04 pm
rallydiesel
  • 1880
Re: better turbo!
« Reply #4 on: November 16, 2009, 02:28:04 pm »
A K24 or T3 from a 1.6 would do well on the AAZ. Although you could certainly run around 130 hp on the stock turbo with a boost controller and upping your fueling. An intercooler would be a good idea at this point too.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #5November 16, 2009, 08:26:05 pm
4wheeler
Re: better turbo!
« Reply #5 on: November 16, 2009, 08:26:05 pm »
If the stock turbo is a K03 you won`t get 130 hp at 18-20PSI.
110 at most
If the stock turbo is a K14 is the stock turbo 130hp is doable.
Reply #6November 16, 2009, 08:39:10 pm
blackdogvan
  • 574
Re: better turbo!
« Reply #6 on: November 16, 2009, 08:39:10 pm »
I'm pretty sure when he said k03 hybrid he meant k03 hybrid. As in ko3 cold side k04 hotside. Bora parts & kermatdi both sell them too. K14 would be great too for sure.
1991 Vanagon 1.9 mTDI
Reply #7November 17, 2009, 02:12:27 am
Mozza
  • 81
Re: better turbo!
« Reply #7 on: November 17, 2009, 02:12:27 am »
will the k14 just bolt straight on or will it need some work, and are the giles pumps expensive and where would you get one from! I have to get all the breaks working and some welding done to in the next couple of months! so there are long term ideas,
I have fitted the the intercooler of the 1.6 engine but needed some quick cash and had to sell the complete 1.6 engine with turbo and pump, wish i didnt now, but oh well we do some silly things from time to time.
Reply #8November 17, 2009, 07:45:28 am
4wheeler
Re: better turbo!
« Reply #8 on: November 17, 2009, 07:45:28 am »
There are 2  Standard 1.9TD aaz turbos, the  K03 and K14.
All depends on how much power you want from your motor..
Reply #9November 17, 2009, 08:49:33 am
wildenbeast
  • 50
    • The WILDENBEAST
Re: better turbo!
« Reply #9 on: November 17, 2009, 08:49:33 am »
The Garrett T2 turbo was also standard for some years on the 1.9TD (1.9 AAZ Turbo Diesel engines 93-98 yr.  Garrett T-2;  VW # 028 145 703 B and VD2431F).  This uses a 4-bolt turbo flange.  For my elevation, a T2 or a K14 are the only stock options due to boost lag.  I would be willing to try a GT series turbo from Garrett once my T2 needs to be replaced.  The T2 is basically Garrett's version of the K14 but seems easier to rebuild.
Here's a link to his website.  Very nice guy and willing to talk you through it all too; http://www.performancediesel.ca/index.htm
1990 Syncro Adventurewagen
1.9 Turbo Diesel (AAZ)
http://billwildenberg.shutterfly.com/vwvanagon
Reply #10November 17, 2009, 09:06:56 am
GEE-BEE
  • 1604
Re: better turbo!
« Reply #10 on: November 17, 2009, 09:06:56 am »
You will be probly see more K14 in Europe , check out ebay Germany
I found a K14 with exhaust manifold for 160.00 euro in Germany ( non egr type )
I purchsed on to help Techtonicstuning with there downpipe requirements for the AAZ/ MK1
They now have both setup's K03 and K14/T3
Next add a PD150 INTAKE and  intercooler and your there
Gee-Bee
Giles Pump OHC
MK1 JETTA DASH
Reply #11November 18, 2009, 09:55:47 am
55eta
Re: better turbo!
« Reply #11 on: November 18, 2009, 09:55:47 am »
As for the pump Peugeot 306or 405s  1.9 td are basically the same as the vw 1.6td  pumps and are set up for 90 hp stock but make sure its a 1.9 not a 1.8 as they are 8mm pumps as opposed to 9mm on the 1.9 but both are set up for 90 odd bhp and if you can be bothered to sort out the electronic cold start the peugeot 406 uses a 10mm pump also a lot of the citroen diesels use the peugeot xud range of engines and same pumps
Reply #12November 18, 2009, 10:08:14 am
55eta
Re: better turbo!
« Reply #12 on: November 18, 2009, 10:08:14 am »
forgot to say if you go down the pug 406 road the 180 bar injectors from the same car makes a  nice addition to the 10mm pump
Reply #13November 19, 2009, 07:55:26 am
anto
Re: better turbo!
« Reply #13 on: November 19, 2009, 07:55:26 am »
406 pumps are 9mm heads as well im sorry to say and the injectors are 175 bar same as a 1.9 306/405.
Dont waste time with a 406 pump due to the electrics headache, that solenoid controls advance as well through an ecu.
Reply #14November 19, 2009, 08:05:25 am
4wheeler
Re: better turbo!
« Reply #14 on: November 19, 2009, 08:05:25 am »
So many more diesel options across the pond.
You guys over there are so lucky.
Damn oil companies tieing north america to gasoline.
